Does the route result simplified when using direction widget?
1417
06-04-2017 08:04 PM
LeoDeng
How to avoid simplified with direction widget?  Can I set the parameters with JS API OR on arcgis routing service?
LeoDeng
Solution:
Uncheck the parameters Simplification Tolerance.
Network Dataset Properties > Travel Modes > Simplification Tolerance.
Travel modes—Help | ArcGIS Desktop
LeoDeng
Solution:
