does not show map  with  <form id="form1" runat="server">
1257
08-19-2013 07:21 AM
JoseSanchez
hi all
I downloaded a javascipt sample, opened it with .Net and imported the index file inside a Defaultaspx page
when I open the default.aspx page it fails to show the map if it encounters the tags:
  - <form id="form1" runat="server">
  -  </form>
I want to create a new .Net project replacing all the Web ADF functions with Javascript, and the most important to reuse the ASP/VBnet code that runs fine and does not use calls to web ADF Libraries.
Commenting the <form> tag the maps shows correctly.
<body class="soria">
     <div id="mainWindow" dojotype="dijit.layout.BorderContainer" design="headline"
    gutters="false" style="width:100%; height:100%;">
      <div id="header" dojotype="dijit.layout.ContentPane"  class="roundedCorners" region="top">
        This is the header section
      </div>
      <div id="map" dojotype="dijit.layout.ContentPane" class="roundedCorners" region="center"></div>
      <div dojotype="dijit.layout.ContentPane" id="rightPane" class="roundedCorners" region="right"  splitter="true" >
        <button dojoType="dijit.form.Button"  onClick="toolBar.activate(esri.toolbars.Draw.EXTENT);">Select</button>
        <button dojoType="dijit.form.Button"  onClick="toolBar.deactivate();featureLayer.clearSelection();">Clear</button>
        <table dojotype="dojox.grid.DataGrid" jsid="grid" id="grid" style="width:100%;height:100%;" selectionMode="none">
         <thead>
            <tr>
              <th field="depth">Depth</th>
              <th field="magnitude" width="100%">Magnitude</th>
            </tr>
          </thead>
        </table>
      </div>
      <div id="footer" class="roundedCorners" dojotype="dijit.layout.ContentPane" region="bottom">
        This is the footer section
      </div>
      </div>
    </form>
BrianRassier
We've noticed something similar.  When we have our map defined within a <form> tag, the <div> that contains the map is forced to 400px.  Has anyone else noticed this?
BrianRassier
Quick update.  I ran into this post which explained styling the <form> tag.  This seemed to fix what I'm seeing for now.
http://forums.arcgis.com/threads/64889-DOJO-Layout-Inside-ASP.NET-Web-Form
