Do not show item in LayerList
3713
04-18-2019 04:00 PM
GregoryBologna
JS 4.11
I am looking for a way to loop through the layers before they get added to my LayerList object and hide some layers.
I can use listItemCreatedFunction: function (event) { } to access the layers and sublayers, but setting layer items visible to false does not work.
I tried using LayerListViewModel but I could not find documentation on the class, and it just blows up on function not found.
const layerListViewModel = new LayerListViewModel()({
    view: view
layerListViewModel.listItemCreatedFunction = function (event) {
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-LayerList-LayerListViewMo...
Tags (1)
GregoryBologna
Thanks. I implemented this code to hide subitems.
                  if (item.layer.allSublayers && item.layer.allSublayers.length > 0) {
                    item.layer.allSublayers.forEach(function (item) {
                      if (item.sublayers && item.sublayers.length > 0) {
                        item.sublayers.forEach(function (item) {
                          item.listMode = "hide";
KellyHutchins
Esri Notable Contributor
You'll want to use the listMode property on the layer in order to hide it from the list:
https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-Layer.html#listMode
GregoryBologna
NicoKroes
Is there a way to hide layers in the LayerList widget in ArcGIS API for Javascript in the 3.23 version of the API? I do not believe that the listMode property is available on ArcGIS API for Javascript in the 3.23 version.
KenBuja
MVP Esteemed Contributor
This thread shows how to do that with a map scene.https://community.esri.com/thread/232289-remove-layers-from-the-layerwidget
