Distance Measurement Component - change initial tool display
1766
04-29-2025 10:56 AM
PeteVitt
Hi  - is there any way to change the initial display for the Distance Measurement 2D Component to use an icon (like the default calcite measure-line icon) instead of the large button labeled 'New Measurement'?  I've tried specifying the icon in the html markup like below, but I still get the 'New Measurement' button on my map. The map on my application is fairly small so I don't have a lot of real estate for the big button
 <arcgis-distance-measurement-2d position="top-right" icon="measure-line"></arcgis-distance-measurement-2d>
Thanks
Pete
Justin_Greco
That icon property just controls the icon when the component is inside an expand component.  It doesn’t affect the new measurement button.
PeteVitt
I see that the Distance Measurement 2D widget has not been deprecated yet:  https://developers.arcgis.com/javascript/latest/components-transition-plan/
maybe this is why the icon property isnt working for the component?
Pete
Justin_Greco
PeteVitt
Thanks Justin - so it sounds like I just need to put the meas tool inside an expand component to get the behavior I want
