Distance calculation
1039
05-02-2019 01:56 AM
MarkBalman
Hi all
I am struggling with how to return a distance from a drawn geometry (polygon, extent, circle) that is buffered (user specified distance) and which then selects any features within that object. At the moment, I get the distance from the centre point of the object (A) and not the edge of the buffer start edge (B). Hopefully the following graphic should illustrate better what I need to calculate:
Here is the code I am using (Version 3.28 api):
/* function to create toolbar drawing shapes */
function initToolbar(evt) {
tb = new Draw(map);
tb.on("draw-complete", addGraphic);
// event delegation so a click handler is not needed for each individual button
on(dom.byId("info"), "click", function(evt) {
if ( evt.target.id === "info" ) {
return;
var tool = evt.target.id.toLowerCase();
map.disableMapNavigation();
tb.activate(tool);
function addGraphic(evt) {
//deactivate the toolbar and clear existing graphics
tb.deactivate();
map.enableMapNavigation();
var geometry = evt.geometry;
var params = new BufferParameters();
params.distances = [dom.byId("distance").value];
params.outSpatialReference = map.spatialReference;
params.unit = GeometryService[dom.byId("unit").value];
var symbol;
if ( geometry.type === "point" || geometry.type === "multipoint") {
userMP = evt.geometry;
symbol = markerSymbol;
} else if ( geometry.type === "line" || geometry.type === "polyline") {
userMP = geometry;
symbol = lineSymbol;
} else if ( geometry.type === "extent") {
userMP = geometry.getCenter();
else {
userMP = geometry.getCentroid();
symbol = fillSymbol;
params.geometries = [geometry];
esriConfig.defaults.geometryService.buffer(params, showBuffer);
map.graphics.add(new Graphic(geometry, symbol));
function showBuffer(bufferedGeometries) {
var symbol = new SimpleFillSymbol(
SimpleFillSymbol.STYLE_SOLID,
new SimpleLineSymbol(
SimpleLineSymbol.STYLE_SOLID,
new Color([255,0,0,0.65]), 2
new Color([255,0,0,0.35])
arrayUtils.forEach(bufferedGeometries, function(geometry) {
var graphic = new Graphic(geometry, symbol);
map.graphics.add(graphic);
on(esriConfig.defaults.geometryService, "buffer-complete", function(Geom){
queryMapService(Geom)
/* Function to query layers based on tool geometry chosen e.g. polygon, circle etc */
function queryMapService(Geom){
var promises = [];
/* query for feature layers */
var query = new Query();
query.outFields = ["*"];
query.returnGeometry = false;
query.geometry = Geom.geometries[0];
function findClosestIBAs(features) {
var geometryService = new GeometryService("../arcgis/rest/services/Utilities/Geometry/GeometryServer");
var promises;
var dlist = [];
var list = [];
var rstr = "";
var ptloc, distp;
for (var x = 0; x < features.length; x++) {
var distParams = new DistanceParameters();
distParams.distanceUnit = GeometryService.UNIT_KILOMETER;
distParams.geometry1 = userMP;
distParams.geodesic = true;
SitRecID = features.attributes["SitRecID"];
IntName = features.attributes["IntName"];
ptloc = features.geometry;
distParams.geometry2 = features.geometry;
dlist.push({name:IntName + " " + SitRecID, loc:ptloc});
distp = geometryService.distance(distParams);
list.push(distp)
All(list).then(lang.hitch(this,function(results){
var shortestDist = Number.POSITIVE_INFINITY;
var closestBlock = "";
for (var dv = 0; dv < dlist.length; dv++){
appendSensIBAs(dlist[dv].name + " is " + results[dv].toFixed(2) + "km");
rstr += dlist[dv].name + " is " + results[dv].toFixed(2) + "km";
if(results[dv] < shortestDist){
shortestDist = results[dv];
closestBlock = dlist[dv].name;
Any ideas or suggestions gratefully received!
Thanks in advance,
Mark
KenBuja
MVP Esteemed Contributor
For the distance1 parameter, you're putting in the original geometry that the user drew instead of the buffered feature
