Display Results for 2 Layers?
2053
7
02-29-2012 11:37 AM
EmilyLaMunyon
Hi all,
I have a Javascript web map in which the user manually selects layers by dragging a box, using the Identify Task. I have it working where if features from one layer are selected, the results are displayed in a datagrid. The problem I am having is if two layers overlap and the user selects them both, I can't figure out how to display results for both. I have tried multiple things and am yet to come up with a solution. I am open to either having both datagrids displayed at the bottom, or giving the user a choice through a pop-up window of which grid results to show. The last chunk of the else/if statement where I try to put both the layers together does not seem to be working....any ideas????
Thanks so much!!!
 dojo.connect(map, 'onLoad', function(theMap) {
      navToolbar.deactivate();
           identifyTask = new esri.tasks.IdentifyTask("http://slcarcgisdev1/SLCOGIS/rest/services/public/Surveyor/MapServer");
           identifyParams = new esri.tasks.IdentifyParameters();
           identifyParams.tolerance = 3;
           identifyParams.returnGeometry = true;
           identifyParams.layerIds = [0,2];
           identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL;
           identifyParams.width  = map.width;
           identifyParams.height = map.height;
          //initialize the toolbar
          toolBar = new esri.toolbars.Draw(map);
          dojo.connect(toolBar, "onDrawEnd",onDrawEnd);
          //resize the map when the browser resizes
          dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
      function onDrawEnd(extent){
          executeIdentifyTask(extent);
 function executeIdentifyTask(geom) {
        //clear the graphics layer
           map.graphics.clear();
        var polygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DOT,    new   dojo.Color([151, 249,0,.80]), 3), new dojo.Color([151, 249, 0, 0.45]));
        var markerSymbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE, 20, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([0, 0, 0]), 1), new dojo.Color([25,50,225,0.3]));
        identifyParams.geometry = geom;
        identifyParams.mapExtent = map.extent;
        identifyTask.execute(identifyParams,function(response){
            var controlItems = [];
            var surveyItems = [];
           dojo.forEach(response,function(result){
               var feature = result.feature;
                //add selected feature to graphics layer
                feature.setSymbol(polygonSymbol);
                feature.setSymbol(markerSymbol);
                map.graphics.add(feature);
               if(result.layerName === 'Control Points'){
               showPointNameGrid();
               controlItems.push(feature.attributes);
               searchType = "selControl";
              var controlStore = new dojo.data.ItemFileReadStore({data:{identifier:'POINT_NAME',items:controlItems}});
              var grid = dijit.byId('grid4');
              grid.setStore(controlStore);
         }else if(result.layerName === 'surveys'){
           showSurveysNameGrid();
           surveyItems.push(feature.attributes);
           searchType="selSurveys";
           var surveysStore = new dojo.data.ItemFileReadStore({data:{identifier:'DOCUMENT_N',items:surveyItems}});
           var grid = dijit.byId('grid5');
           grid.setStore(surveysStore);
          }else if((result.layerName === 'surveys') && (result.layerName === 'Control Points')){
            var surveysStore = new dojo.data.ItemFileReadStore({data:{identifier:'DOCUMENT',items:surveyItems}});
HemingZhu
Hi all,
Thanks so much!!!
One approach I would try is to store the identify results in seperate data stores, and then dynamically build/rebuild the datagrid(s) based on users choice (one or both)...
EmilyLaMunyon
Thanks so much for the answer!:)
That is what I was trying to accomplish with the code I originally posted.
Is it possible to get information for two layers using the following code?
HemingZhu
Without context, I cannot really tell whether your function would work. It should work.
EmilyLaMunyon
Thanks again for the reply!
I am trying to set-up a situation where if the user of the map manually selects overlapping features using the Identify task, both results will display in seperate datagrids at the bottom of the screen.
I have it working if only one layer is selected, results are displayed in the datagrid. I also have it working where if two layers are selected, they highlight as such on the map. I am just stuck on how to show the results of the selection in 2 datagrids at the bottom of the page. I am also open to having a propmt that allows the user to chose which results to show after selecting both layers.
I hope that makes sense. The part that seems to be broken is where I try and get results for both layers using the && operator. The alert does not even display in the section of code.Below is the relevant code.
I really appreciate any advice you have!! Sorry to be such a newbie.:confused:
 //SELECT STUFF
             if (result.layerName === 'surveys' && result.layerName === 'Control Points'){
             alert(result.layerName);
           }else if(result.layerName === 'Control Points'){
            //update the data grid
                    searchType="selSurveys2";
HemingZhu
 //SELECT STUFF
You might want to change you logic flow in your function. Here is the example:
           if (result.layerName =="surveys"){
             //alert(result.layerName);
    else{
         if(surveyItems.length >0){
  if(controlItems.length >0){
EmilyLaMunyon
Thanks so much!!! I got it to work!
I really appreciate your help with this 😉
EmilyLaMunyon
I thought this was working, and it almost is, when any one feature is selected by dragging a selection box, the results display fine. The problem arises when the selection box selects two overlapping features from different layers. I want results from all selected features to display in their respective data grids, or give the user an option to chose which data grid results to show. Currently, it seems that only the surveys results are displaying, even though the Control Points are being selected as well. Any advice on how to remedy this? Could it be because Control Points are a point layer and they do not have length?
Thanks for any help!:confused:
           identifyParams.layerIds = [0,1,2];
    }else if (result.layerName=="Control Points"){
