Display and Tie datagrid to graphic circle radius query
1720
08-12-2019 01:03 PM
CarlSunderman
I am drawing a circle radius at one mile and selecting all features that fall within the circle. I want to highlight the selected features and show them in a data grid/ table, and as i click around the map, to update the table along with the selected features.
I am able to draw the circle and select the features. i'm also able to console.log the output, but can't figure out how to create the datagrid thats tied the the selected records and clear the table on each new selection.
    <!DOCTYPE html>
    <html>
    <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
        on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Buffer</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/tundra/tundra.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
    <style>
        html,
        body,
        #mapDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        #messages {
        background-color: #fff;
        box-shadow: 0 0 5px #888;
        font-size: 1.1em;
        max-width: 15em;
        padding: 0.5em;
        position: absolute;
        right: 20px;
        top: 20px;
        z-index: 40;
        #drop {
        font-size: 1.1em;
        max-width: 15em;
        padding: 0.5em;
        position: absolute;
        right: 20px;
        top: 105px;
        z-index: 40;
    </style>
    <script src="http://js.arcgis.com/3.11/"></script>
    <script>
        var map;
        require([
            "esri/map", "esri/layers/FeatureLayer",
            "esri/tasks/query", "esri/geometry/Circle", "esri/units",
            "esri/graphic", "esri/InfoTemplate", "esri/symbols/SimpleMarkerSymbol",
            "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "esri/renderers/SimpleRenderer",
            "esri/config", "esri/Color", "dojo/dom", "dijit/form/ComboBox", "dojo/domReady!"
        ], function (
        Map, FeatureLayer,
        Query, Circle, Units,
        Graphic, InfoTemplate, SimpleMarkerSymbol,
        SimpleLineSymbol, SimpleFillSymbol, SimpleRenderer,
        esriConfig, Color, dom
        // use a proxy page if a URL generated by this page is greater than 2000 characters
        // this should not be needed as nearly all query & select functions are performed on the client
        esriConfig.defaults.io.proxyUrl = "/proxy/";
        map = new Map("mapDiv", {
            basemap: "streets",
            center: [-81.00, 34.000],
            zoom: 14,
            slider: false
        //selected features are clicked a popup window will appear displaying the content defined in the info template.
        var featureLayer = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/0", {
            outFields: ["POP2000", "HOUSEHOLDS", "HSE_UNITS", "TRACT", "BLOCK"]
        // selection symbol used to draw the selected census block points within the buffer polygon
        var symbol = new SimpleMarkerSymbol(
            SimpleMarkerSymbol.STYLE_CIRCLE,
            6,
            new SimpleLineSymbol(
            SimpleLineSymbol.STYLE_NULL, new Color([200, 120, 101, 0.9]), 1),
            new Color([200, 0, 0, 1])
        featureLayer.setSelectionSymbol(symbol);
        //make unselected features invisible
        var nullSymbol = new SimpleMarkerSymbol().setSize(0);
        featureLayer.setRenderer(new SimpleRenderer(nullSymbol));
        map.addLayer(featureLayer);
        var circleSymb = new SimpleFillSymbol(
            SimpleFillSymbol.STYLE_NULL,
            SimpleLineSymbol.STYLE_SHORTDASHDOTDOT,
            new Color([105, 105, 105]),
            ), new Color([255, 255, 0, 0.25])
        var circle;
        //when the map is clicked create a buffer around the click point of the specified distance.
        map.on("click", function (evt) {
            selbuf = document.FormSelection.BufferSelection.selectedIndex;
            var BufferSelection = document.FormSelection.BufferSelection.options[selbuf].value;
            circle = new Circle({
            center: evt.mapPoint,
            geodesic: true,
            radius: BufferSelection,
            radiusUnit: Units.MILES
            map.graphics.clear();
            map.infoWindow.hide();
            var graphic = new Graphic(circle, circleSymb);
            map.graphics.add(graphic);
            var query = new Query();
            query.geometry = circle;
            featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function (results) {
            console.log(results)
            var features = results.features;
            console.log(features)
    </script>
    </head>
    <body>
    <span id="messages">Click on the map to select by radius within mile.</span>
    <span id="drop">  Select Radius Size
        <form name="FormSelection">
        <select name="BufferSelection">
            <option>1</option>
            <option>2</option>
            <option>10</option>
        </select>
        </form>
    </span>
    <div id="mapDiv"></div>
    </body>
    </html>
Tags (1)
RobertScheitlin__GISP
Here is a sample that is almost exactly what you are describing.
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <title>Map with a Dojo dGrid</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.25/dojo/resources/dojo.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.25/dgrid/css/dgrid.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.25/dgrid/css/skins/tundra.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.25/dijit/themes/tundra/tundra.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.25/esri/css/esri.css">
  <style>
    html,
    body {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
      overflow: hidden;
    #container {
      height: 100%;
      visibility: hidden;
    #bottomPane {
      height: 200px;
    .left {
      float: left;
      width: 50%;
      overflow: hidden;
      height: 200px;
    .right {
      float: left;
      width: 50%;
      overflow: hidden;
      height: 200px;
    .dgrid {
      border: none;
    .field-id {
      cursor: pointer;
  </style>
  <script src="http://js.arcgis.com/3.25/"></script>
  <script>
    // load dgrid, esri and dojo modules
    // create the grid and the map
    // then parse the dijit layout dijits
    require([
      "dgrid/OnDemandGrid",
      "dgrid/Selection",
      "dojo/store/Memory",
      "dojo/_base/array",
      "dojo/dom-style",
      "dojo/dom-attr",
      "dijit/registry",
      "esri/map",
      "esri/Color",
      "esri/config",
      "esri/tasks/QueryTask",
      "esri/tasks/query",
      "esri/graphic",
      "esri/dijit/PopupTemplate",
      "dojo/_base/declare",
      "dojo/number",
      "dojo/on",
      "dojo/_base/lang",
      "dojo/parser",
      "dijit/layout/BorderContainer",
      "dijit/layout/ContentPane",
      "dojo/domReady!"
    ], function(
      Grid,
      Selection,
      Memory,
      array,
      domStyle,
      domAttr,
      registry,
      Map,
      FeatureLayer,
      SimpleMarkerSymbol,
      SimpleLineSymbol,
      SimpleFillSymbol,
      Color,
      esriConfig,
      SimpleRenderer,
      QueryTask,
      Query,
      Circle,
      Graphic,
      PopupTemplate,
      InfoTemplate,
      declare,
      dojoNum,
      on,
      lang,
      parser
      esriConfig.defaults.io.proxyUrl = "proxy/Proxy.ashx"
      parser.parse();
      // create the dgrid
      window.grid = new(declare([Grid, Selection]))({
        // use Infinity so that all data is available in the grid
        bufferRows: Infinity,
        columns: {
          "id": "ID",
          "popuplation": {
            "label": "2000 Population",
            "formatter": dojoNum.format
          "households": "Households",
          "houseunits": "House Units"
      }, "grid");
      // add a click listener on the ID column
      grid.on(".field-id:click", selectBlkPnt);
      grid.on("th.field-households:mouseover", function(evt){
        if(domAttr.get(evt.target, "title") !== "Blah Blah"){
          domAttr.set(evt.target, "title", "Blah Blah");
      // create the dgrid
      window.grid2 = new(declare([Grid, Selection]))({
        columns: {
          "id": "ID",
          "popuplation": {
          "white": "White",
          "black": "Black",
          "asian": "Asian"
      }, "grid2");
      window.map = new Map("map", {
        basemap: "streets",
        center: [-95.249, 38.954],
        zoom: 14,
      window.blockUrl = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/0";
      window.blockGroupURL = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/1";
      window.outFields = ["OBJECTID", "POP2000", "HOUSEHOLDS", "HSE_UNITS"];
      window.bgoutFields = ["OBJECTID", "POP2000", "WHITE", "BLACK", "ASIAN"];
      var fl = new FeatureLayer(window.blockUrl, {
        outFields: window.outFields
      var fl2 = new FeatureLayer(window.blockGroupURL, {
        outFields: window.bgoutFields
      // Selection symbol used to draw the selected census block points within the buffer polygon
        12,
          new Color([247, 34, 101, 0.9]),
        new Color([207, 34, 171, 0.5])
      fl.setSelectionSymbol(symbol);
      var symbol2 = new SimpleFillSymbol(
          SimpleLineSymbol.STYLE_SOLID,
          new Color([247, 0, 0, 1]),
        new Color([0, 0, 0, 0.5])
      fl2.setSelectionSymbol(symbol2);
      // Make unselected features invisible
      fl.setRenderer(new SimpleRenderer(nullSymbol));
      var nullSymbol2 = new SimpleFillSymbol().setStyle(SimpleFillSymbol.STYLE_NULL).setOutline(null);
      fl2.setRenderer(new SimpleRenderer(nullSymbol2));
      fl.on("click", selectGrid);
      // change cursor to indicate features are click-able
      fl.on("mouse-over", function() {
        window.mapClickEvt.pause();
        map.setMapCursor("pointer");
      fl.on("mouse-out", function() {
        setTimeout(function() {
          window.mapClickEvt.resume();
        }, 800);
        map.setMapCursor("default");
      map.addLayer(fl);
      map.addLayer(fl2);
      var circle;
      // When the map is clicked create a buffer around the click point of the specified distance
      window.mapClickEvt = on.pausable(map, "click", function(evt) {
          geodesic: true,
          radius: 1,
          radiusUnit: "esriMiles"
        // Use a fast bounding box query. It will only go to the server if bounding box is outside of the visible map.
        fl.selectFeatures(query, FeatureLayer.SELECTION_NEW, selectInBuffer);
        fl2.selectFeatures(query, FeatureLayer.SELECTION_NEW, selectInBuffer2)
      function selectInBuffer2(features) {
        console.info(features);
        var data = array.map(features, function(feature) {
          return {
            // property names used here match those used when creating the dgrid
            "id": feature.attributes[window.bgoutFields[0]],
            "popuplation": feature.attributes[window.bgoutFields[1]],
            "white": feature.attributes[window.bgoutFields[2]],
            "black": feature.attributes[window.bgoutFields[3]],
            "asian": feature.attributes[window.bgoutFields[4]]
        var memStore = new Memory({
          data: data
        window.grid2.set("store", memStore);
      function selectInBuffer(features) {
          return {
            "id": feature.attributes[window.outFields[0]],
            "popuplation": feature.attributes[window.outFields[1]],
            "households": feature.attributes[window.outFields[2]],
            "houseunits": feature.attributes[window.outFields[3]]
          data: data
        window.grid.set("store", memStore);
      map.on("load", function(evt) {
        // show the border container now that the dijits
        // are rendered and the map has loaded
        domStyle.set(registry.byId("container").domNode, "visibility", "visible");
      // fires when a row in the dgrid is clicked
      function selectBlkPnt(e) {
        var fl = map.getLayer("blockPnts");
        query.objectIds = [parseInt(e.target.innerHTML, 10)];
        query.returnGeometry = true;
        fl.queryFeatures(query, function(results) {
          var gra = results.features[0].clone();
            12,
              new Color([247, 247, 0, 1]),
            new Color([247, 247, 0, 0.9])
          gra.setSymbol(symbol);
          map.graphics.add(gra);
      // fires when a feature on the map is clicked
      function selectGrid(e) {
        var id = e.graphic.attributes.OBJECTID;
        // select the corresponding row in the grid
        // and make sure it is in view
        grid.clearSelection();
        grid.select(id);
        grid.row(id).element.scrollIntoView();
  </script>
</head>
<body class="tundra">
  <div id="container" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design: 'headline', gutters: false">
    <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region: 'center'"></div>
    <div id="bottomPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region: 'bottom'">
      <div id="grid" class="left"></div>
      <div id="grid2" class="right"></div>
    </div>
  </div>
</body>
</html>
KenBuja
MVP Esteemed Contributor
Take a look at this sample that uses a dgrid: dgrid | ArcGIS API for JavaScript 3.29
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
      overflow: hidden;
    #container {
      height: 100%;
      visibility: hidden;
    #bottomPane {
      height: 200px;
    .left {
      float: left;
      width: 50%;
      overflow: hidden;
      height: 200px;
    .right {
      float: left;
      width: 50%;
      overflow: hidden;
      height: 200px;
    .dgrid {
      border: none;
    .field-id {
      cursor: pointer;
  </style>
  <script>
    require([
      "dgrid/Selection",
      "dojo/_base/array",
      "dojo/dom-style",
      "dojo/dom-attr",
      "dijit/registry",
      "esri/map",
      "esri/Color",
      "esri/config",
      "esri/tasks/query",
      "esri/graphic",
      "dojo/number",
      "dojo/on",
      "dojo/_base/lang",
      "dojo/parser",
      "dojo/domReady!"
    ], function(
      Grid,
      Selection,
      Memory,
      array,
      domStyle,
      domAttr,
      registry,
      Map,
      FeatureLayer,
      SimpleMarkerSymbol,
      SimpleLineSymbol,
      SimpleFillSymbol,
      Color,
      esriConfig,
      SimpleRenderer,
      QueryTask,
      Query,
      Circle,
      Graphic,
      PopupTemplate,
      InfoTemplate,
      declare,
      dojoNum,
      on,
      lang,
      parser
      parser.parse();
      // create the dgrid
        columns: {
          "id": "ID",
          "popuplation": {
      }, "grid");
      // create the dgrid
        columns: {
          "id": "ID",
          "popuplation": {
          "white": "White",
          "black": "Black",
          "asian": "Asian"
      }, "grid2");
        basemap: "streets",
        zoom: 14,
        12,
        }, 800);
      map.addLayer(fl);
      map.addLayer(fl2);
      var circle;
          geodesic: true,
          radius: 1,
          return {
          data: data
          return {
          data: data
            12,
        grid.select(id);
  </script>
</head>
    </div>
  </div>
</body>
</html>
