Disable zoom widget on mobile device screen only
2354
09-26-2023 07:09 AM
JaredPilbeam2
This works to remove it completely with v. 4.27.
const view = new MapView({
  container: "viewDiv",
  map: map,
  // Exclude the zoom widget from the default UI
  ui: {
    components: ["attribution"]
The sample code doesn't mention how to disable the zoom widget on mobile device only. Is that possible? It's not so practical and takes up too much room.
ReneRubalcava
Esri Frequent Contributor
You can watch for changes to the widthBreakpoint or heightBreakpoint of the View.
https://developers.arcgis.com/javascript/latest/api-reference/esri-views-MapView.html#widthBreakpoin...
https://developers.arcgis.com/javascript/latest/api-reference/esri-views-MapView.html#heightBreakpoi...
Then you can add/remove widgets as needed.
watch(
	() => view.widthBreakpoint,
	(breakpoint) => {
		switch (breakpoint) {
			case "xsmall":
			case "small":
				view.ui.remove("zoom");
				break;
			default:
				if (!view.ui.find("zoom")) {
					view.ui.add("zoom", "top-left");
Here's a demo:
https://codepen.io/odoe/pen/OJrZVVW?editors=0011
ReneRubalcava
watch(
	(breakpoint) => {
			case "xsmall":
			case "small":
				break;
			default:
Here's a demo:
JaredPilbeam2
Is the search widget not included? I've put "search" and "Search"  in the ui.compenents and they cause an error.
ui.components = [
  "attribution",
  "zoom",
  "search"
ReneRubalcava
Search can't be added by string, I think it's just "zoom", and "attribution"
