Disable popup on web component feature search
818
04-17-2026 08:45 AM
JaredPilbeam2
I can't seem to disable the popup on the search component for a feature layer. Here is a simple sample. To recreate my problem search "man". Click MANHATTAN under town. There's a popup on this feature I can't get rid of.
I've been looking and trying all the relevant properties I can find for both the arcgis-search and arcgis-features to disable the popup. Nothing worked sofar. I've included popup-disabled in the arcgis-map component too. Is there a  way to stop the popup in the code and not on the feature itself in AGOL?
EDIT: I should add in my actual app I have other feature layers that I want popups enabled so I can't really disable them in the arcgis-map component.
MatthewDriscoll
'popupEnabled: false' should work fine.  You place it in the individual search component, the other layers should not be affected.
search.sources = [
    layer: muni,
    searchFields: ["NAME"],
    displayField: "NAME",
    exactMatch: false,
    outFields: ["NAME"],
    placeholder: "search by town",
    popupEnabled: false   // ******
    name: "ArcGIS World Geocoding Service",
    placeholder: "example: Nuuk, GRL",
    singleLineFieldName: "SingleLine",
    apiKey: "YOUR_ACCESS_TOKEN",
    url: "https://geocode-api.arcgis.com/arcgis/rest/services/World/GeocodeServer",
    popupEnabled: false
MatthewDriscoll
search.sources = [
    layer: muni,
    exactMatch: false,
    popupEnabled: false
MatthewDriscoll
I got a chance to play around with this and saw what you are talking about.  It looks like you are using a popup in AGOL, and using that SAME layer for your search in the SDK.  The SDK will assign the popupEnable globally to that layer.  You created a bit of a mess mixing the two on the same layer.  The only way I could figure out is to disable all popups, then recreating the popup all over again.  I have a feeling it will buggy, AGOL settings might keep trying to re-enter the chat.
    view.map.add(muni);
    const search = document.querySelector("arcgis-search");
    await search.componentOnReady();
    search.sources = [{
      layer: muni,
      exactMatch: false,
      popupEnabled: false
    // Stop ALL popups.
    view.popup.autoOpenEnabled = false;
    // Track when search is happening
    let fromSearch = false;
    search.addEventListener("arcgisSearchSelectResult", async (event) => {
      fromSearch = true;
      const result = event.detail.result;
      await view.goTo(result.extent || result.feature.geometry);
    // Kill popup AFTER it appears
    reactiveUtils.when(
      () => view.popup?.visible === true,
        if (fromSearch) {
          view.popup.visible = false;
          fromSearch = false;
    // restore popup
    view.on("click", async (event) => {
      const hit = await view.hitTest(event);
      const result = hit.results.find(r => r.graphic.layer === muni);
      if (result) {
        view.popup.open({
          features: [result.graphic],
JaredPilbeam2
Sorry to put you through that. Your first response worked. I swore I tried that.
MatthewDriscoll
Glad to help.  I also tried that and didn't get the results I expected.  No worries, these exercises help me keep up with things outside my normal day to day stuff.
