Disable Info Window while Measuring
10415
17
08-19-2013 02:24 PM
EmilyLaMunyon
I have an application that utilizes an Identify Task to select and show a popup Info Window on certain layers. This works fine until
the Measurement Widget is activated and an Info Window popups up every time a distance is measured. I have come across many threads that deal with this issue but have had no luck implementing any of them. How do I deactivate the Info Window when
using the Measure Widget? Any help is greatly appreciated!!
//Measurement Tool       var measurement = new esri.dijit.Measurement({              map: map,     defaultLengthUnit: esri.Units.FEET,      }, dojo.byId('measurementDiv'));             measurement.startup();                       dojo.connect(measurement, "onMeasureEnd", function(activeTool,geometry){          this.setTool(activeTool, false),    });  //Identify Event function executeIdentifyTask(evt) {             identifyParams.geometry = evt.mapPoint;         identifyParams.mapExtent = map.extent;         var deferred = identifyTask.execute(identifyParams);          deferred.addCallback(function(response) {              return dojo.map(response, function(result) {         var feature = new esri.Graphic(result.feature.toJson());;                        feature.attributes.layerName = result.layerName;         if(result.layerName === 'Section Corners' || result.layerName === 'Accessory Monuments'){          // console.log(feature.attributes.POINT_NAME);          var template = new esri.InfoTemplate("Monuments", "Point Name: ${POINT_NAME}<br/><a target='_blank'  href='http://surveyor.slco.org/jsapi/map/mrs_javamap.cfm?LAT=${LATITUDE}&LONG=${LONGITUDE}&POINT_NAME=${POINT_NAME}'>Mon. Ref. Sheet</a>");          feature.setInfoTemplate(template);             }             else if (result.layerName === 'Surveys'){             var template = new esri.InfoTemplate("Surveys", "${SURVEYOR}<br/> Survey Number: ${DOCUMENT_N}<br/><a target='_blank' href='http://surveyor.slco.org/jsapi/map/sire_survey_image.cfc?page_id=${page_id}'>Survey PDF Document</a>");               feature.setInfoTemplate(template);             }                 return feature;           });         });                    map.infoWindow.setFeatures([ deferred ]);         map.infoWindow.show(evt.mapPoint);       }
JasonZou
Change:
    dojo.aspect.after(measurement, "setTool", toggleIdentify, true);
To:
EmilyLaMunyon
Change:
To:
Jason, again, thanks so much. I have no idea why, but this is still not working. This is what I have, and the popups are still appearing when I measure. Sorry to be such a pain...
var identifyHandler = (map,"onClick",executeIdentifyTask);
            map: map,
       function toggleIdentify(measurement, activate) {
    // disable identifyHandler when measurement tool is set and activated
    if (activate && identifyHandler) {
        dojo.disconnect(identifyHandler);
        identifyHandler = null;
    // activate identify tool otherwise
    else {
        identifyHandler = (map, "onClick", executeIdentifyTask);
  measurement.deactivate = function() {
         var locationBtn = dijit.byId('location'),
         distanceBtn = dijit.byId('distance'),
         areaBtn = dijit.byId('area')
  this.closeTool();
  locationBtn.setAttribute('checked', false);
  distanceBtn.setAttribute('checked', false);
  areaBtn.setAttribute('checked', false);
//Identify Task
function mapReady(map){
       dojo.connect(map,"onClick",executeIdentifyTask);
       //create identify tasks and setup parameters
       identifyTask = new esri.tasks.IdentifyTask("http://gis10.slco.org/SLCOGIS/rest/services/public/Surveyor_New/MapServer");
       identifyParams = new esri.tasks.IdentifyParameters();
       identifyParams.tolerance = 8;
       identifyParams.returnGeometry = true;
       identifyParams.layerIds = [1,2,4];
       identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL;
       identifyParams.width  = map.width;
       identifyParams.height = map.height;
              var template = new esri.InfoTemplate("Surveys", "${SURVEYOR}<br/> Survey Number: ${DOCUMENT_N}<br/>Address: ${ADDRESS_OF_SURVEY}<br/><a target='_blank' href='http://surveyor.slco.org/jsapi/map/sire_survey_image.cfc?page_id=${page_id}'>Survey PDF Document</a>");
            return feature;
JasonZou
Open the app in Chrome and start the Developer Tools. Set a breakpoint at the first statement inside toggleIdentify. Will the app reach the breakpoint when you click any of the measurement tools?
EmilyLaMunyon
I put the break point on:
and the app reaches it, but in the scope variables in Chrome developer it says that activate is undefined.
JasonZou
Ok. After some testing, this should work. Change toggleIdentify function as below.
function toggleIdentify(toolName) {
    var isMeasurementActive = measurement[toolName].checked;
    if (isMeasurementActive) {
    else {
        identifyHandler = map.on("click", executeIdentifyTask);
EmilyLaMunyon
Jason,
Your advice was great, and I appreciate your time, I just could not get it to work with my application. I did finally figure it out, and
hopefully this helps someone else with the same issue.
function executeIdentifyTask(evt) {        var measureMode =   dojo.query(".esriButton .dijitButtonNode").some(function(node, index, arr){             if(node.childNodes[0].checked){             //at least one of the measure tools is active so disable identify             return true;                        }        });        if(! measureMode){         map.graphics.clear();         identifyParams.geometry = evt.mapPoint;         identifyParams.mapExtent = map.extent;          var deferred = identifyTask.execute(identifyParams);         deferred.addCallback(function(response) {              return dojo.map(response, function(result) {         var feature = new esri.Graphic(result.feature.toJson());;               feature.attributes.layerName = result.layerName;             if(result.layerName === 'Section Corners' || result.layerName === 'Accessory Monuments'){                         var template = new esri.InfoTemplate("Monuments", "Point Name: ${POINT_NAME}<br/><a target='_blank' href='../../mrs_javamap.cfm?LAT=${LATITUDE}&LONG=${LONGITUDE}&POINT_NAME=${POINT_NAME}'>Mon. Ref. Sheet</a>");               feature.setInfoTemplate(template);             }             else if (result.layerName === 'Surveys'){           var template = new esri.InfoTemplate("Surveys", "${SURVEYOR}<br/> Survey Number: ${DOCUMENT_N}<br/>Address: ${ADDRESS_OF_SURVEY}<br/><a target='_blank' href='../../sire_survey_image.cfc?page_id=${page_id}'>Survey PDF Document</a>");               feature.setInfoTemplate(template);             }                 return feature;           });         });                    map.infoWindow.setFeatures([ deferred ]);         map.infoWindow.show(evt.mapPoint);       }     }
AdrianMarsden
Honored Contributor
Oddly my code I had a different approach, which broke when I moved to API 3.7
I had hooked the onclick of the tool to a routine, disableID(), that set a global variable - which I then checked against on my id function
        dojo.connect(measurement, "onClick", function() {
            navToolbar.deactivate();
            ClearAllButtonsIcon();
            disableID();
Since 3.7 none of this event gets triggered - using your method of checking works fine - so many thanks.
Anyone any ideas why my old code broke at 3.7? I haven't tried using the newer style "on" way of linking to events yet.
Cheers
ACM
VincentAwino
Hi jason,
I'm quit new to ArcGIS JavaScript API, so its a little difficult to follow the thread here. could you get me a simple example where you use a PopupTemplate  and disable the Popup when using the Measurement widget. id greatly appreciate. thanks a lot. In case you need to check out my code view here http://jsfiddle.net/vince_awino/D3J8H/15/
