directions widgets clickmap also adds coordinates not address
2640
10-11-2015 12:56 AM
lasinh
i used geododeService  in directions widgets, but My code did not work as I expected, when i clickMap to add a point to input parameter of directions widgets also adds at coordinates instead of address. How to adds Address to input directions widgets? thanKYou
My Code:
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Directions Widget</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
    <style>
      html, body, #map {
        height:100%;
        width:100%;
        margin:0;
        padding:0;
      body {
        background-color:#FFF;
        overflow:hidden;
        font-family:"Trebuchet MS";
    </style>
    <script src="http://js.arcgis.com/3.14/"></script>
    <script>
        require([
       "esri/map", "esri/tasks/locator", "esri/dijit/Directions", "esri/dijit/Search", "esri/layers/FeatureLayer",
        "dojo/parser",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
      ], function (
         Map, Locator, Directions, Search, FeatureLayer,
        parser
          parser.parse();
          //all requests to route.arcgis.com will proxy to the proxyUrl defined in this object.
          map = new Map("map", {
              zoom: 0
          var tiled = new esri.layers.ArcGISTiledMapServiceLayer("url");
          map.addLayer(tiled);
          var directions = new Directions({
              map: map,
              mapClickActive: true,
              routeTaskUrl: "url",
              geometryTaskUrl: "url",
             // travelModesServiceUrl: "http://utility.arcgis.com/usrsvcs/servers/cdc3efd03ddd4721b99adce219629489/rest/services/World/Utili...",
              searchOptions: {
                  sources: [
                  locator: new Locator("url"),
                  singleLineFieldName: "SingleLine",
                  name: "Custom Geocoding Service",
                  placeholder: "Search Geocoder",
                  maxResults: 3,
                  maxSuggestions: 20,
                  enableSuggestions: true,
                  minCharacters: 0
          }, "dir");
          directions.startup();
    </script>
  </head>
  <body class="claro">
    <div data-dojo-type="dijit/layout/BorderContainer"
         data-dojo-props="design:'headline', gutters:false"
         style="width:100%;height:100%;">
      <div data-dojo-type="dijit/layout/ContentPane"
           data-dojo-props="region:'right'"
           style="width:250px;">
        <div id="dir"></div>
      </div>
      <div id="map"
           data-dojo-props="region:'center'">
      </div>
    </div>
  </body>
</html>
Tags (1)
