Directions widget crash on reset() or removeStops()
1369
08-24-2017 10:49 AM
RubenBueno
I've ran into an issue when managing stops through javascript, where removing all stops by either using reset() or removeStops results in an error that renders the widget unusable and leaves orphaned layers on the map:
here's the codepen with an array of stops to try it:
https://codepen.io/rbuenon/pen/MvBoba
As the screenshot shows, you can add the stops with 'dirs.addStops(stops)' and after it calculates the route, try removing all stops with 'dirs.removeStops()' or 'dirs.reset()'.
the error doesn't always happen on the first try.
Things I've tried:
- Add the stops as Points
- Add the stops as all Stops (no waypoints)
- Add the stops as Graphics
- Add the stops as an object with a graphic feature
- Add all stops, then all waypoints
Any pointers on how to solve this or work around it?
Thanks in advance.
DmitryKudinov
Ruben,
Thank you for reporting this issue. It has be reproduced and will be addressed in 3.22.
Regards,
Dmitry
