Definition expression only applies to some of the data instead of all of it
5684
17
04-02-2019 09:34 AM
MKF62
I create a definition expression on a featureLayer through it's relationship with table. The definition expression gets applied to the table first, then the definition expression for the featureLayer is created and applied. The definition expression is pulling records of a certain year in the table, then through it's relationship with the featureLayer I get GUIDs of those that match the pulled records in the table and set the featureLayer's definition expression based on those GUIDs. The problem is that for some years this works and for others it doesn't. I can see in the debugger that the definition expression gets created correctly for the featureLayer, but when I apply it to the featureLayer, nothing displays on the map. If I switch the year to another year, the definition expression gets applied and the appropriate polygons appear for that year. If I switch back to the previous year, again, no polygons are displayed, even though they exist for that year. It's pretty odd behavior and I'm not sure why this would be happening.
Records in the table when the definition expression is set to YearTreated = 2015.
Records in the related feature layer that match these MgmtTractIDs
My code should produce a definition expression like this for application to the featureLayer:
var de = "MgmtTractID = '{...}' OR MgmtTractID = '{...}' OR MgmtTractID = '{...}'
..so on and so forth
Apply that definition expression to the feature layer and I get nothing displayed on the map. This definition expression works for 2009, 2010, 2011, 2012, 2013, 2014, 2017, 2018, and 2019. It doesn't work for 2008, 2015, or 2016. I have checked and rechecked that the DE is being created correctly with formatting and that the MgmtTractIDs do indeed show up in the related feature layer. Everything looks fine.
on(dom.byId("data-year"), "change", function () {
    var year = dom.byId("data-year").value;
    //Defintion expressions are already set upon first load of the map, don't need to recalculate
    //if the year hasn't been changed. A change event is fired on load of the map.
    if (year !== currentYear) {
        hbMgmtTableFL.setDefinitionExpression('YearTreated = ' + year);
        hbMgmtTableFL.refresh();
        //The habitat management feature layer needs to be filtered using the related table.
        getTractDefExpression();
function getTractDefExpression() {
    var recordIDs = new Query();
    recordIDs.where = "1=1";
    hbMgmtTableFL.queryIds(query, function (OIDs) {
        if (OIDs !== null) {
            //Create relationship query
            var relatedRecordsQuery = new RelationshipQuery();
            relatedRecordsQuery.objectIds = OIDs;
            relatedRecordsQuery.outFields = ["MgmtTractID"];
            relatedRecordsQuery.relationshipId = 0;
            hbMgmtTableFL.queryRelatedFeatures(relatedRecordsQuery, function (fset) {
                //Get all MgmtTractIDs for the current year from the table
                //The table already has it's definition expression set, so it'll
                //only pull the MgmtTractIDs for the year that is set
                var MgmtTractIDsArr = [];
                for (i = 0; i < OIDs.length; i++) {
                    var OID = OIDs[i];
                    var features = fset[OID].features;
                    var mgmtTractId = features[0].attributes.MgmtTractID;
                    if (!(MgmtTractIDsArr.includes(mgmtTractId))) {
                        MgmtTractIDsArr.push(mgmtTractId);
                //Create the definition expression for the feature layer
                var whereClause;
                for (i = 0; i < MgmtTractIDsArr.length; i++) {
                    if (i == 0) {
                        whereClause = "MgmtTractID = '" + MgmtTractIDsArr[i] + "'";
                    else {
                        whereClause = whereClause + " OR MgmtTractID = '" + MgmtTractIDsArr[i] + "'";
                //Set the polygon feature layer's definition expression based on the GUIDs
                debugger;
                hbMgmtTractFL.setDefinitionExpression(whereClause);
                hbMgmtTractFL.refresh();
        else {
            debugger;
            hbMgmtTractFL.setDefinitionExpression('MgmtTractID = 0');
Tags (1)
RobertScheitlin__GISP
Have you tried to console.log the exact SQL that is being applied when it fails and apply that to the layer in Desktop to see if it works? Also I normally do an IN( '...','...') SQL query if I have more than a couple of values instead of using OR.
MKF62
I have tried it in Desktop and it works as expected. Thanks for the tip on the "IN" - I did that and 2015 and 2016 data started showing up. Still doesn't show 2008 data though...
That makes it sounds like there is a problem with the SQL statement then. Sorry it is not going to be easy for me to help you on this.
MKF62
I understand. It's just odd because it generates the statement and when I try it in Desktop it works.
I can't see anything wrong with this:
MgmtTractID IN(
'{B1CE758E-4CA2-469E-9933-8746DFACA3EF}',
'{A37D1BE3-005A-4D2C-AE76-6B30E98AF981}',
'{BBA93CA8-08F0-4DF5-9EFE-6F4EDF5664D2}',
'{75CC656A-BDBC-4BFA-A6A0-1B1BA62DE105}',
'{88E58225-D2A1-4E35-8E79-9EE5B17A94A3}',
'{CD2B81CA-1FF3-4930-932C-1E88F1AF1C9D}',
'{5483E110-E6E2-46BE-98E5-3BE2ED0F60BF}',
'{BE01BA5D-C604-494B-BCB6-4160AB5474E1}',
'{0FA279E3-38E1-4BAC-910B-6991066B97D3}',
'{A6D44511-C057-42D8-8096-B7A84D80BE82}',
'{9B8F4664-0E2D-452B-AE2D-34768A0BFC0B}',
'{75E9C08C-3E14-4344-B35A-57CCF41D1497}',
'{7EEED5DC-3C1E-49DA-AE89-445E35D3BA7A}',
'{1A52D3FA-FE09-4996-8F0D-4FA6EB68F121}',
'{CD343F57-A2DF-43D8-8616-872CF8514E16}',
'{F4E855C9-0A45-4B0E-A5D8-4C02178733B7}',
'{4814C6C4-C583-4F8E-81FA-122FBA807EFE}',
'{0ECFC833-928C-4B9C-96F0-F75F31FCD7B9}',
'{305D7D13-8CEF-4253-A7AC-B418852FA37C}',
'{3249A913-299E-43FF-82F2-EA76DF8C7FD0}',
'{22432A46-E938-49DF-B1AA-E52347DA5BAF}',
'{907B11E8-77E1-4C65-B6B4-A41F0DD9B44E}',
'{801E7790-5715-44F8-9F26-97BCA0FCF0AD}',
'{C90E76A7-F195-4B6C-ADF0-50D7BCB8BB9E}',
'{0A00ACB3-5759-40CF-AD90-739406DFD4C5}',
'{35D8BDC1-EF20-4185-86B1-3C6DB6F08412}',
'{95E3803D-8797-47A5-BB68-D69A45711B1C}',
'{7556D941-DF86-464E-B9F6-1194241479EB}',
'{DC3B0C72-4FB7-4042-81F4-297F6F254330}'
Molly,
  Sorry I don't see a problem either.
MKF62
Just noticed in my console that I get 404 Not Found errors when I try to query for 2008 data, don't receive that for any of the other years. I use a proxy to access my data, haven't the slightest why it'd only be one year that it can't query. I'll keep working on it, report back if I figure it out. Thanks for your help.
Can you show me a screenshot of the error?
MKF62
It gives me this 30 times in the console (I think if you click on them you can make them bigger?):
From the network tab:
When I double click the red line in the network tab:
If the "query string is too long" is referring to the MgmtTractID query I make, then that's really weird because 2008 has the least amount of IDs to query. Other years have upwards of 200. This one only has 29.
Edit: Actually, the requested URL here is much longer than the others, so it does have to do with it being quite long. The other successful queries just make a request to the MapServer url:
Molly,
  Right click on the url in the console tab and choose open in new tab. Does it provide results or error?
