dateformat in Attribute Inspector
1792
06-25-2014 04:37 PM
Town_ofSnowflake
Is it possible to display both the date AND the time using the Attribute Inspector?
shortDateshortTime doesn't seem to display a time
AndyGup
@meloking, I'm not sure however have you tried specifying a TimeTextBox as a custom widget to the Attribute Inspector?
Here are two examples to demonstrate what I'm suggesting:
Attribute Inspector sample with custom widget: https://developers.arcgis.com/javascript/jssamples/ed_attributeInspectorValidate.html
Dojo TimeTextBox: http://dojotoolkit.org/reference-guide/1.10/dijit/form/TimeTextBox.html
-Andy
StevenGraf1
Here is a link for formatting infoWindow content.  It might help get you started.  I'm not sure if the commands are the same for the AttributeInspector.
Here is a sample where they format AttributeInspector content
Hope this helps
JonathanUihlein
Unfortunately, the AttributeInspector widget does not currently support time by default.
However, it has been updated for the next release (due out before the UC).
