Customize Search option for a Feature Layer
1567
01-19-2017 10:01 AM
SarojThapa1
My Search option is pointing to a feature layer that has a few features. Each feature of this feature layer refers to  a particular region in the map. I was thinking about creating a drop down list inside the search option. As a result, a user can  choose from the drop downs and ENTER. After that, the map should zoom into the region the feature points to.
Is that possible or should I use QueryTask to achieve this?
RobertScheitlin__GISP
Saroj,
   I believe that you would be much better off using a QueryTask for this then trying to customize the Search Dijit.
Saroj,
SarojThapa1
Thank you Robert!
