custom map tool javasctipt
7649
10
06-07-2016 03:11 PM
Dave_J_Zhang
Hi, I am new to ArcGIS JavaScript API, I would like to create custom tool on my web app, I search internet, it seems all I can find is custom widget, for example I want to develop custom tool when click the map just display the x, y values in a custom dialog showing where the mouse clicked, and query the feature layer. how can I get started? The following is the sample I took from esri website and I want to add my custom tool to the group, but it does not work. I don't know what I did wrong here, Can anyone help? Thank you in advance.
Dave
<!DOCTYPE html>
<html>
  <head>
    <title>Shapes and Symbols</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/css/esri.css">
    <style>
      #info {
        top: 20px;color: #444;height: auto;  font-family: arial;right: 20px;  margin: 5px;
        padding: 10px;  position: absolute;  width: 115px;  z-index: 40;  border: solid 2px #666;
        border-radius: 4px;   background-color: #fff;
      html, body, #mapDiv {    padding:0;    margin:0;      height:100%;  }
      button {  display: block;  }
    </style>
    <script src="https://js.arcgis.com/3.16/"></script>
    <script>
      var map, tb;
      require([
        "esri/map", "esri/toolbars/draw",
        "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol",
        "esri/symbols/PictureFillSymbol", "esri/symbols/CartographicLineSymbol",
        "esri/graphic", "esri/Color", "dojo/dom", "dojo/on", "dojo/domReady!"
      ], function(
        Map, _Draw,
        SimpleMarkerSymbol, SimpleLineSymbol, PictureFillSymbol, CartographicLineSymbol,
        _Graphic, Color, dom, on
        map = new Map("mapDiv", {
          basemap: "streets",
          center: [-25.312, 34.307],
          zoom: 3
        map.on("load", initToolbar);
        // markerSymbol is used for point and multipoint, see http://raphaeljs.com/icons/#talkq for more examples
        var markerSymbol = new SimpleMarkerSymbol();
        markerSymbol.setPath("M16,4.938c-7.732,0-14,4.701-14,10.5c0,1.981,0.741,3.833,2.016,5.414L2,25.272l5.613-1.44c2.339,1.316,5.237,2.106,8.387,2.106c7.732,0,14-4.701,14-10.5S23.732,4.938,16,4.938zM16.868,21.375h-1.969v-1.889h1.969V21.375zM16.772,18.094h-1.777l-0.176-8.083h2.113L16.772,18.094z");
        markerSymbol.setColor(new Color("#00FFFF"));
        // lineSymbol used for freehand polyline, polyline and line.
        var lineSymbol = new CartographicLineSymbol(
          CartographicLineSymbol.STYLE_SOLID,
          new Color([255,0,0]), 10,
          CartographicLineSymbol.CAP_ROUND,
          CartographicLineSymbol.JOIN_MITER, 5
        // fill symbol used for extent, polygon and freehand polygon, use a picture fill symbol
        // the images folder contains additional fill images, other options: sand.png, swamp.png or stiple.png
        var fillSymbol = new PictureFillSymbol("images/mangrove.png",
          new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,new Color('#000'),1), 42, 42);
        function initToolbar() {
          tb = new _Draw(map);
          tb.on("draw-end", addGraphic);
          // event delegation so a click handler is not
          // needed for each individual button
          on(dom.byId("info"), "click", function(evt) {
            //alert(evt.target.id); //show up
            if ( evt.target.id === "info" ) {
              return;
            var tool = evt.target.id.toLowerCase();
            map.disableMapNavigation();
            if(tool != "mycustomtool")
                tb.activate(tool);
            else
                  on(map, "click", function Map_Click()  {  alert("custom tool");  } )  //this will never show up
        function addGraphic(evt) {
          //deactivate the toolbar and clear existing graphics
          tb.deactivate();
          map.enableMapNavigation();
          // figure out which symbol to use
          var symbol;
          if ( evt.geometry.type === "point" || evt.geometry.type === "multipoint") {
            symbol = markerSymbol;
          } else if ( evt.geometry.type === "line" || evt.geometry.type === "polyline") {
            symbol = lineSymbol;
          else {
            symbol = fillSymbol;
          map.graphics.add(new _Graphic(evt.geometry, symbol));
    </script>
  </head>
  <body>
    <div id="info">
      <div>Select a shape then draw on map to add graphic</div>
      <button id="Point">Point</button>
      <button id="Multipoint">Multipoint</button>
      <button id="Line">Line</button>
      <button id="Polyline">Polyline</button>
      <button id="FreehandPolyline">Freehand Polyline</button>
      <button id="Triangle">Triangle</button>
      <button id="Extent">Rectangle</button>
      <button id="Circle">Circle</button>
      <button id="Ellipse">Ellipse</button>
      <button id="Polygon">Polygon</button>
      <button id="FreehandPolygon">Freehand Polygon</button>
      <button id="MyCustomeTool">Custom tool</button>
    </div>
    <div id="mapDiv"></div>
  </body>
</html>
PanagiotisPapadopoulos
Hi Dave glad to hear that helped.
Please mark the conversation as answered for future searches.
