Custom Labels for Graphics ? (AMD)
1032
03-19-2014 11:40 AM
MarkCunningham1
I am trying to add custom labels to graphics points. Each graphic having its own unique label. Thanks for the help.
<!DOCTYPE HTML>
<html>
<head>
  <meta charset="utf-8">
  <title>Basemap Toggle</title>
  <link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.8/js/esri/css/esri.css">
  <style>
    html, body, #map {
      padding:0;
      margin:0;
      height:100%;
  </style>
  <script src="//js.arcgis.com/3.8/"></script>
  <script>
var map;
    require([
      "esri/map",
      "dojo/domReady!"
    ], function(
      Map
    var map = new Map("map", {
        center: [-81.057, 34.005],
        zoom: 7,
        basemap: "national-geographic",
        fadeOnZoom: true,
        slider: false,
        nav: false,
   wrapAround180: true,
        //------Add Point Graphic------------------------------
   require(["dojo/_base/Color","esri/lang","esri/graphic","esri/layers/GraphicsLayer","esri/renderers/SimpleRenderer",
        "esri/geometry/Point","esri/tasks/FeatureSet","esri/symbols/SimpleMarkerSymbol","esri/symbols/SimpleLineSymbol", "dojo/domReady!" ],
    function( Color, esriLang, Graphic, GraphicsLayer, SimpleRenderer, Point, FeatureSet, SimpleMarkerSymbol, SimpleLineSymbol){
    var facilityPointSymbol = new SimpleMarkerSymbol(
      SimpleMarkerSymbol.STYLE_CIRCLE, 15,  new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([60,50,255]), 2 ),new Color([169,250,20,0.6]));
  var facilitiesGraphicsLayer = new GraphicsLayer();
   var facilityRenderer = new SimpleRenderer(facilityPointSymbol);
   facilitiesGraphicsLayer.setRenderer(facilityRenderer);
map.addLayer(facilitiesGraphicsLayer);
  facilitiesGraphicsLayer.add(new Graphic(new Point(-83.538,33.063,map.spatialReference)));
  facilitiesGraphicsLayer.add(new Graphic(new Point(-82.959,34.025,map.spatialReference)));
  facilitiesGraphicsLayer.add(new Graphic(new Point(-81.039,35.025,map.spatialReference)));
  facilitiesGraphicsLayer.add(new Graphic(new Point(-81.099,36.001,map.spatialReference)));
   var facilities = new FeatureSet();
   facilities.features = facilitiesGraphicsLayer.graphics;
   //---End Point Graphic--------
  </script>
</head>
<body>
  <div id="map" class="map">
  </div>
</body>
</html>
JakeSkinner
Esri Esteemed Contributor
Hi Jamie,
Take a look at using the TextSymbol class.  Here is an example.
JakeSkinner
Hi Jamie,
