Create Label Symbol for Interstate
1400
03-06-2024 08:06 AM
kapalczynski
I have a line feature that I want to Label with an interstate symbol and put text in it from a field...
Not sure how to so this with Javascript Api 4.x
I see here that you can label by creating a label class and applying it to the Feature Layer but not sure how to make it an interstate Shield and populate the text via a field value
https://developers.arcgis.com/javascript/latest/sample-code/labels-basic/
Thoughts?
MatthewDriscoll
Maybe a Picture Marker Symbol?  Maybe play around in the symbol builder?  Honestly it might be easiest to create in Pro and host it.
BlakeTerhune
It looks to be possible, but I'm not sure how to implement it. I've not worked with CIMSymbol.
Esri Web Style Symbols (2D) | Overview | ArcGIS Maps SDK for JavaScript 4.29 | ArcGIS Developers
Maybe this video demo on Dynamic Vector Symbology will help.
JohnGrayson
Esri Alum
As Matt suggested, I too would recommend the use of CIMSymbols and the symbol builder app which is a great way to help us get started. I used the symbol builder to mock up the symbol json for the line layer and then I updated one of the samples to create this CodePen, which I then further tweaked to connect the label text to a feature attribute via the primitive overrides and Arcade.  Hopefully these links will help in your task.
