Create a chart with javascript
1364
07-19-2022 08:01 AM
KARIMLABIDI
Hello,
I would like to create a chart with chart Js and that's not easy! I would like to load a json from my AGE rest and after that,create a cumulative chart with the length of my polyline.
My code blocks when I try to load data,it gives me a error 'undefined (reading Map)'. I don't know what to do.
The data looks like this
Any help would very appreciated 🙂
ReneRubalcava
Esri Frequent Contributor
Is miseservice an array? Too tough to tell from a screenshot, but sounds like that property is not an array you can map over
KARIMLABIDI
Thank you for your answer. I took this link to try to make the same thing . From an URL Json , I should be able to load data but I don't know if my data ara in array.
https://www.youtube.com/watch?v=oFLnXT7D4gc.
If I can't map over , do you how I can I load data in my chart?
Thank you
