Could not load class 'dijit.layout.BorderContainer
899
12-03-2012 10:53 PM
Udaya_BhaskerCheerala
Hi All,
I have developd a map with TOC, Navigation Toolbar and some other query options using Javasctipt API in .aspx page. When I run it individually, it is working perfectly, but I want to embed it into another .net application.
In .NET application I have a page with one dropdown with various options. Upon selection of option from dropdown I need to show the above said map.
Iam getting below error.
**Message: Could not load class 'dijit.layout.BorderContainer
Line: 15
Char: 133114
Code: 0
URI: http://myserver/arcgis_js_api/library/3.1/jsapi/**
I have hosted Javascript API in my local IIS.
Can anyone help me how to resolve the above issue.
Uday
BenFousek
What do you mean embed in another .net app?
When you get the the 'Could not load class 'dijit.layout.BorderContainer' it's usually because of a javascript syntax error, like a missing ;, malformed code, etc. The reason you get the BorderContainer error is because it's the first thing dojo parses in your code. I suspect in your case there is some conflict when you put it all together. Post some code or the stack from the error.
