CoordinateConversion format to show DMS + elevation
1832
12-27-2022 06:42 AM
Leandro-Zamudio
Hi, following the CoordinateConversion custom format in the documentation I've implemented the widget correctly in my 4.24 app.
But now i need to show the lat/long in DMS, it's like combining these two
This is my format code
    const numberSearchPattern = /-?\d+[\.]?\d*/;
    const newFormat = new Format({
      // Nombre único e información del Formato
      conversionInfo: {
        convert: function (point) {
          const returnPoint = point.spatialReference.isWGS84
            ? point
            : webMercatorUtils.webMercatorToGeographic(point);
          const x = returnPoint.x.toFixed(2);
          const y = returnPoint.y.toFixed(2);
          const z = returnPoint.z.toFixed(2)/2;
          return {
            coordinate: `${x}, ${y}, ${z}`
        reverseConvert: function (string) {
          const parts = string.split(",");
          return new Point({
            x: parseFloat(parts[0]),
            y: parseFloat(parts[1]),
            z: parseFloat(parts[2]),
            spatialReference: { wkid: 4326 }
      coordinateSegments: [
          alias: "X",
          description: "Longitud",
          searchPattern: numberSearchPattern
          alias: "Y",
          description: "Latitud",
          alias: "Z",
          description: "Elevación",
      defaultPattern: "X°, Y°, Zm"
 Note: The Z value is divided by 2 because the WebScene has a 2x exaggeration.
Thanks in advance
GreteSoosalu
Hi @Leandro-Zamudio
In such a case, it is the best to break the coordinates already into degrees-minutes-seconds inside the conversionInfo and adjust the coordinateSegments accordingly.
For pre-formatting the point's coordinates into "40 50 02.55N 121 31 54.83W" pattern, you can use the coordinateFormatter converter:
coordinateFormatter.toLatitudeLongitude(returnPoint, "dms", 3)
Here's an example app that shows the widget with a custom DMS format with Z values: https://codepen.io/gsoosalu/pen/xxJRjMX
Hope this helps you further.
Leandro-Zamudio
Hi @GreteSoosalu
I watched the codepen but it doesn't show the custom coordinate format but reading the code and re-thinking it I could solve it breaking the coordinates as you suggested. For further reference I share the solution of the same code but corrected:
      conversionInfo: {
            ? point
          const x = Math.trunc(returnPoint.x);
          const a = Math.trunc(-(returnPoint.x-x)*60);
          const b = (-(returnPoint.x-x-(a/-60))*3600).toFixed(2);
          const y = Math.trunc(returnPoint.y);
          const c = Math.trunc(-(returnPoint.y-y)*60);
          const d = (-(returnPoint.y-y-(c/-60))*3600).toFixed(2);
          //console.log(b)
          return {
            coordinate: `${x}, ${a}, ${b}, ${y}, ${c}, ${d}, ${z}`
//For now i'm not using the reverseConvert function so I left it as is
          return new Point({
        {alias: "X", description: "Longitud Grados", searchPattern: numberSearchPattern},
        {alias: "A", description: "Longitud Minutos", searchPattern: numberSearchPattern},
        {alias: "B", description: "Longitud Segundos", searchPattern: numberSearchPattern},
        {alias: "Y", description: "Latitud Grados", searchPattern: numberSearchPattern},
        {alias: "C", description: "Latitud Minutos", searchPattern: numberSearchPattern},
        {alias: "D", description: "Latitud Segundos", searchPattern: numberSearchPattern},
        {alias: "Z", description: "Elevación", searchPattern: numberSearchPattern}
      defaultPattern: "X° A\' B\", Y° C\' D\", Zm"
I'd like to know more about the Regular expressions that you used to find a number, is there any reference to read about it?
      // Regular expressions to find a number
      const number2Digit = /\d{1,2}[\.|\.]?\d*/i; // Same as CoordinateConversion widget's DMS format uses
      const number3Digit = /\d{1,3}[\.|\.]?\d*/i; // Same as CoordinateConversion widget's DMS format uses
Thanks for your help
GreteSoosalu
Oh, you're right, there was a bug in my app. It should be fixed now, so the custom format should be shown:
And thanks @Leandro-Zamudio for sharing the fixed code that works for you!
GreteSoosalu
Regarding the Regular expressions, I cannot think of any references at the moment but if I find anything, I'll post it here.
