Controlling zoom scales
3937
07-28-2014 10:37 AM
Gayathri_PriyaRavichandran
Hi all,
        I would like to know how to control zoom scales or fix like 5-6 zoom factors for a map . I would also like to know if I can control the zoom factors by  using a zoom scale file. Thanks in advance.
AnthonyGiles
Honored Contributor
Gayathri
you will need to add more detail if you want a decent reply from somebody.  What language or application are you requesting the info for?
I am sorry for the inadequate information provided before.
I am working on a web application using javascript. I require to control the zoom scales as there are some zoom scales which are not required.
AnthonyGiles
Honored Contributor
Gayathri,
you can specify what zoom scales you wish to use by using the LODs property of the map:
Specify LODs (levels of detail) | ArcGIS API for JavaScript
example here:
Limiting LODs displayed on map
