Control the size of edit pane/info whindow when using editing widget
814
10-26-2010 01:52 PM
LuhuaCai
Been working on an application that uses the editing widget, similar to this example: http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/ed_selectionmo...
I want to change the size of popup info Window which allows the editing of attributes. I tried to play with the "map.infoWindow.resize(200,200);" command, but it does not work.
Any idea on how to control the size of the info window?
Thanks.
Lu
