Conflict Between Regular Point Marker and Cluster Points
3484
09-02-2015 09:45 AM
BruceGreen
I have two functions `
createPoints(); and addClusters();
to create points and cluster points from JSON point values and I am switching the map presentation (Points<-->Cluster) by suing a Chechbox like :
 if($("input[type='checkbox'][name='clusterPoints']").is(':checked')) {
       createPoints();
   }else{ addClusters();}
  $("input[type='checkbox'][name='clusterPoints']").change(function(){
    if($(this).is(':checked')){
        map.removeLayer(clusterLayer);
        map.graphics.show();
    else{
        map.graphics.hide();
        addClusters();
now after switching from Cluster to Points, I am missing the points InfoTemplate(); (not poping up on points on click) but the Cluster PopupTemplate(s) work fine . Here is the how code:
            function createPoints(){
                for (var i = 0; i < mapInfo.length; i++) {
                var project = mapInfo;
                var point = new Point(project.Longitude, project.Latitude);
                var pointSymbol = new SimpleMarkerSymbol();
                pointSymbol.setStyle(SimpleMarkerSymbol.STYLE_CIRCLE);
                pointSymbol.setSize(12);
                var pointInfoTemplate = new InfoTemplate();
                pointInfoTemplate.setTitle("Project Details");
                pointInfoTemplate.setContent('<div class="list-group marker-info"> <a href="#" class="list-group-item"><div class="row"><span class="col-md-7 marker-info-txt">Project</span><span class="col-md-3 marker-info-txt"><strong>'+project.ProjectID+'</strong></span></div></a> <a href="#" class="list-group-item"><div class="row"><span class="col-md-7 marker-info-txt">Road Length</span><span class="col-md-3 marker-info-txt"><strong>'+project.RoadLength+'</strong></span></div></a> <a href="#" class="list-group-item"><div class="row"><span class="col-md-7 marker-info-txt">Powerline Length</span><span class="col-md-3 marker-info-txt"><strong>'+project.PowerLineLength+'</strong></span></div></a> <a href="#" class="list-group-item"><div class="row"><span class="col-md-7 marker-info-txt">Penstock</span><span class="col-md-3 marker-info-txt"><strong>'+project.Penstock+'</strong></span></div></a> <a href="#" class="list-group-item"><div class="row"><span class="col-md-7 marker-info-txt">Installed Capacity</span><span class="col-md-3 marker-info-txt"><strong>'+project.InstalledCapacity+'</strong></span></div></a><a href="#" class="list-group-item"><div class="row"><span class="col-md-7 marker-info-txt">Annual Firm Energy</span><span class="col-md-3 marker-info-txt"><strong>'+project.AnnualFirmEnergy+'</strong></span></div></a><a href="#" class="list-group-item"><div class="row"><span class="col-md-7 marker-info-txt">Cost Of Energy</span><span class="col-md-3 marker-info-txt"><strong>'+project.CostOfEnergy+'</strong></span></div></a><a href="#" class="list-group-item"><div class="row"><span class="col-md-7 marker-info-txt">Footprint</span><span class="col-md-3 marker-info-txt"><strong>'+project.Footprint+'</strong></span></div></a><a href="#" class="list-group-item"><div class="row"><span class="col-md-7 marker-info-txt">Cost Per Year</span><span class="col-md-3 marker-info-txt"><strong>'+project.CostPerYear+'</strong></span></div></a></div> ');
                var pointGraphic = new Graphic(point, pointSymbol).setInfoTemplate(pointInfoTemplate);
                points.push(pointGraphic);
                for (i = 0; i < points.length; ++i) {
                map.graphics.add(points);
    function addClusters() {
     var project=[];
                project.push(mapInfo);
      var photoInfo = [];
            var wgs = new SpatialReference({
              "wkid": 4326
  photoInfo.data = arrayUtils.map(mapInfo, function(p) {
    var latlng = new Point(parseFloat(p.Longitude), parseFloat(p.Latitude), wgs);
    var webMercator = webMercatorUtils.geographicToWebMercator(latlng);
    var attributes = {
         "Project ID":  p.ProjectID,
         "Road Length": p.RoadLength,
         "Powerline Length": p.PowerLineLength,
         "Penstock": p.Penstock,
         "Installed Capacity": p.InstalledCapacity,
         "Annual Firm Energy": p.AnnualFirmEnergy,
         "Cost Of Energy": p.CostOfEnergy,
         "Footprint": p.Footprint,
         "Cost Per Year": p.CostPerYear,
  return {
        "x": webMercator.x,
        "y": webMercator.y,
        "attributes": attributes
        var popupTemplate = new PopupTemplate({
              "title": "Project Details",
              "fieldInfos": [{
                "fieldName": "Project ID",
                visible: true
                "fieldName": "Road Length",
                 visible: true
                "fieldName": "Powerline Length",
                 visible: true
                "fieldName": "Penstock",
                 visible: true
                "fieldName": "Installed Capacity",
                 visible: true
                "fieldName": "Annual Firm Energy",
                 visible: true
                "fieldName": "Cost Of Energy",
                 visible: true
                "fieldName": "Footprint",
                 visible: true
                "fieldName": "Cost Per Year",
                 visible: true
              "mediaInfos": [{
                "title": "",
                "caption": "",
                "type": "image",
                "value": {
                  "sourceURL": "{Image}",
                  "linkURL": "{Link}"
       clusterLayer = new ClusterLayer({
              "data": photoInfo.data,
              "distance": 100,
              "id": "clusters",
              "labelColor": "#fff",
              "labelOffset": 10,
              "resolution": map.extent.getWidth() / map.width,
              "singleColor": "#888",
              "singleTemplate": popupTemplate
            var defaultSym = new SimpleMarkerSymbol().setSize(4);
            var renderer = new ClassBreaksRenderer(defaultSym, "clusterCount");
            var picBaseUrl = "http://static.arcgis.com/images/Symbols/Shapes/";
            var blue = new PictureMarkerSymbol(picBaseUrl + "BluePin1LargeB.png", 32, 32).setOffset(0, 15);
            var green = new PictureMarkerSymbol(picBaseUrl + "GreenPin1LargeB.png", 64, 64).setOffset(0, 15);
            var red = new PictureMarkerSymbol(picBaseUrl + "RedPin1LargeB.png", 72, 72).setOffset(0, 15);
            renderer.addBreak(0, 2, blue);
            renderer.addBreak(2, 200, green);
            renderer.addBreak(200, 1001, red);
            clusterLayer.setRenderer(renderer);
            map.addLayer(clusterLayer);
            // close the info window when the map is clicked
            map.on("click", cleanUp);
            // close the info window when esc is pressed
            map.on("key-down", function(e) {
              if (e.keyCode === 27) {
                cleanUp();
             function cleanUp() {
            map.infoWindow.hide();
            clusterLayer.clearSingles();
          function error(err) {
            console.log("something failed: ", err);
          window.showExtents = function() {
            var extents = map.getLayer("clusterExtents");
            if ( extents ) {
              map.removeLayer(extents);
            extents = new GraphicsLayer({ id: "clusterExtents" });
            var sym = new SimpleFillSymbol().setColor(new Color([205, 193, 197, 0.5]));
            arrayUtils.forEach(clusterLayer._clusters, function(c, idx) {
              var e = c.attributes.extent;
              extents.add(new Graphic(new Extent(e[0], e[1], e[2], e[3], map.spatialReference), sym));
            }, this);
            map.addLayer(extents, 0);
       createPoints();
    else{
        addClusters();
Can you please let me know why this is happening and how I can fix this? Am using correct functions ` map.graphics.hide();` and map.removeLayer(clusterLayer); to clear map for next presentation in check box switch?
BruceGreen
For what ever reason part of code in points
is not showing in above post! Please check the full code in attached file?
