Component would not be rendered in a DOM element that is added to MapView.ui in V4.33
890
11-17-2025 10:22 AM
AllenHuang
Using JS API V4.33
I was attemping to add a search component into a DOM element and added to the the top right corn of the map.
I used the following code
 let arcgisMap = document.querySelector('arcgis-map');
 let infoPanel = document.createElement('DIV');
 let widget = document.createElement('arcgis-search');
 infoPanel.className = 'infoPanel border';
 infoPanel.innerHTML = 'Info Panel';
 infoPanel.style.borderWidth = '1px';
 infoPanel.style.borderColor = 'blue';
 infoPanel.style.borderStyle = 'solid';
 infoPanel.appendChild(widget);
 arcgisMap.view.ui.add(infoPanel, 'top-right');
However, the arcgis-search component would always be added to the top-left position of the map instead.
I tried the same code in API 4.34 and it was able to render the arcgis-search placement correctly inside the infoPanel element and added to the top-right position of the map.
Did I make a mistake somewhere, or is this a bug in V4.33?
ReneRubalcava
Esri Frequent Contributor
With components, you should not be adding elements to the `view.ui`. You can add them directly to the map component.
In 4.33, you can use the placement component to help with this.
    let placement = document.createElement('arcgis-placement');
    placement.position = "top-right";
    placement.appendChild(infoPanel);
    arcgisMap.appendChild(placement);
https://codepen.io/odoe/pen/YPqVQOp?editors=1001
In 4.34, you can set the `infoPanel.slot ="top-right"` and  `arcgisMap.appendChild(infoPanel)`
ReneRubalcava
AllenHuang
Thanks @ReneRubalcava
This solved my problem.
