Combining two samples (Legend and Info Window Lite) and not working.
2993
10
04-30-2014 03:26 AM
LauraTeisl
From the Samples listed on the ArcGIS API for JavaScript page, I am attempting to combine the Legend (Maps > Legend) and Info Window Lite (Popups and Info Windows > Info Window Lite).  Basically, I can't get it to work, probably due to the fact that I am a JavaScript newbie. Any help would be appreciated!
Code:
<!DOCTYPE html>
<html>
<head>
  <title>Map with legend</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css">
  <style>
    html, body {
      font-family: Tahoma, Geneva, sans-serif;
      height: 97%;
      width: 98%;
      margin: 1%;
    #rightPane {
      width: 20%;
    #legendPane {
      border: solid #97DCF2 1px;
  </style>
  <script src="http://js.arcgis.com/3.9/"></script>
  <script>
    require([
      "esri/map", "esri/layers/FeatureLayer", "esri/dijit/Legend",
      "dojo/_base/array", "dojo/parser", "dojo/dom-construct", "esri/dijit/InfoWindowLite",
      "esri/InfoTemplate",
      "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
      "dijit/layout/AccordionContainer", "dojo/domReady!"
    ], function(
      Map, FeatureLayer, Legend,
      arrayUtils, parser, InfoWindowLite,
      InfoTemplate, domConstruct
      parser.parse();
      var map = new Map("map", {
        basemap:"topo",
        center: [-69, 45.5],
        zoom: 7
      var infoWindow = new InfoWindowLite(null, domConstruct.create("div", null, null, map.root));
        infoWindow.startup();
        map.setInfoWindow(infoWindow);
      var template = new InfoTemplate();
        template.setTitle("<b>${org_name} - ${address}</b>");
        template.setContent("${org_name} is in ${state}");
      var SpecialtyFoodProducers = new FeatureLayer("http://ummgis.umm.maine.edu:6080/arcgis/rest/services/testing/SpecFoodProdGIS428/MapServer/0", {
        mode: FeatureLayer.MODE_ONDEMAND,
  infoTemplate:template,
        outFields: ["org_name" , "address" , "state"]
      //add the legend
      map.on("layers-add-result", function (evt) {
        var layerInfo = arrayUtils.map(evt.layers, function (layer, index) {
          return {layer:layer.layer, title:layer.layer.name};
        if (layerInfo.length > 0) {
          var legendDijit = new Legend({
            map: map,
            layerInfos: layerInfo
          }, "legendDiv");
          legendDijit.startup();
      map.addLayers(SpecialtyFoodProducers);
      map.infoWindow.resize(200, 75);
  </script>
</head>
<body class="claro">
<!--[if IE 7]>
<style>
  html, body {
    margin: 0;
</style>
<![endif]-->
<div id="content"
     data-dojo-type="dijit/layout/BorderContainer"
     data-dojo-props="design:'headline', gutters:true"
     style="width: 100%; height: 100%; margin: 0;">
  <div id="rightPane"
       data-dojo-type="dijit/layout/ContentPane"
       data-dojo-props="region:'right'">
    <div data-dojo-type="dijit/layout/AccordionContainer">
      <div data-dojo-type="dijit/layout/ContentPane" id="legendPane"
           data-dojo-props="title:'Legend', selected:true">
        <div id="legendDiv"></div>
      </div>
           data-dojo-props="title:'Tools'">
        This pane could contain tools or additional content
      </div>
    </div>
  </div>
  <div id="map"
       data-dojo-props="region:'center'"
       style="overflow:hidden;">
  </div>
</div>
</body>
</html>
LauraTeisl
Thank you for replying.  I will check and get back to you.
