Combine Locate Button and Geolocation
6255
06-08-2015 03:39 AM
StevePiercy1
Thanks to a helpful person, I have a working example of a map with a QueryTask.
Now I want to add both Geolocation and a Locate Button. My attempts have been close but buggy. The following is my best effort.
I would greatly appreciate any assistance to add both features to the previous map.
<!DOCTYPE html>
<html>
<head>
<title>Create a Web Map</title>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.13/esri/css/esri.css">
<style>
html,body,#mapDiv,#mapDiv.container{
    padding:20;
    margin:;
    height:650px;
    width:650px;
#LocateButton {
    position: absolute;
    top: 200px;
    left: 20px;
    z-index: 50;
</style>
<script src="http://js.arcgis.com/3.13compact/"></script>
<script type="text/javascript">
// TODO
// zoom to 50 miles
// center map on geolocation, else ZIP code, else CalPoly
// Add Locate Button
// https://developers.arcgis.com/javascript/jssamples/widget_locate.html
// Add search location widget
// https://developers.arcgis.com/javascript/jshelp/intro_search_widget.html
// OR Add geocoder widget
// https://developers.arcgis.com/javascript/jshelp/tutorial_geocoder.html
// http://developers.arcgis.com/javascript/sandbox/sandbox.html?sample=widget_geocoder_tutorial
// remove duplicates nurseries
var map;
window.onload=function(){
    require([
        "esri/map",
        "esri/arcgis/utils",
        "esri/dijit/LocateButton", // locate button
        "esri/geometry/webMercatorUtils", // geolocation
        "esri/geometry/Point", // geolocation
        "esri/layers/DynamicMapServiceLayer",
        "esri/layers/ArcGISDynamicMapServiceLayer",
        "esri/tasks/query",
        "esri/tasks/QueryTask",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/InfoTemplate",
        "dojo/_base/Color",
        "dojo/ready",
        "dojo/domReady!"
        ], function(Map, arcgisUtils, LocateButton, webMercatorUtils, Point, DynamicMapServiceLayer, ArcGISDynamicMapServiceLayer, Query, QueryTask, SimpleMarkerSymbol, InfoTemplate, Color, ready){
        var createMapOptions = {
            mapOptions: {
                basemap: "streets",
                center: [-120.696,37.372],
                zoom: 10
        //create map and add layer
        arcgisUtils.createMap("bf27abedb4dd4197b0fd2237a56d1555", "mapDiv", createMapOptions).then(function (response) {
            map = response.map;
            executeQueryTask(dojo.byId('wholesaler_id').value);
        //initialize query task
        queryTask = new esri.tasks.QueryTask("https://services1.arcgis.com/0j6vZbECadDEXdAS/arcgis/rest/services/Retail_Nurseries/FeatureServer/0");
        //initialize query
        query = new Query();
        query.returnGeometry = true;
        query.outFields = ["name","street_address","city","state","zip_code","telephone","website"];
        //initialize InfoTemplate
        infoTemplate = new InfoTemplate();
        infoTemplate.setTitle(getTextTitle);
        infoTemplate.setContent(getTextContent);
        function getTextTitle(graphic) {
            return graphic.attributes.name;
        function getTextContent(graphic) {
            return (graphic.attributes.street_address + "<br/>"
            + graphic.attributes.city + ", "
            + graphic.attributes.state + " "
            + graphic.attributes.zip_code + "<br/>"
            + graphic.attributes.telephone
            + (String(graphic.attributes.website).length > 0
                & graphic.attributes.website !== null
                ? "<br/><a href=\"" + graphic.attributes.website + "\" target=\"_blank\">website</a>"
        //create symbol for selected features
        symbol = new SimpleMarkerSymbol();
        symbol.setStyle(SimpleMarkerSymbol.STYLE_SQUARE);
        symbol.setSize(10);
        symbol.setColor(new Color([255,255,0,0.5]));
        // geolocation
        function zoomToLocation(location) {
            var pt = webMercatorUtils.geographicToWebMercator(new Point(location.coords.longitude, location.coords.latitude));
            map.centerAndZoom(pt, 10);
        function showLocation(location) {
            if (location.coords.accuracy <= 500) {
                // the reading is accurate, do something
            } else {
                // reading is not accurate enough, do something else
        function locationError(error) {
            switch (error.code) {
                case error.PERMISSION_DENIED:
                    alert("Location not provided");
                    break;
                case error.POSITION_UNAVAILABLE:
                    alert("Current location not available");
                    break;
                case error.TIMEOUT:
                    alert("Timeout");
                    break;
                default:
                    alert("unknown error");
                    break;
        if (navigator.geolocation) {
            navigator.geolocation.getCurrentPosition(zoomToLocation, locationError);
            navigator.geolocation.watchPosition(showLocation, locationError);
        // geolocate
        var geoLocate = new LocateButton({
            map: mapDiv
        }, "LocateButton");
        geoLocate.startup();
function executeQueryTask(wholesaler_id) {
    //set query based on what user typed in for id;
    query.where = "wholesaler_id IN(" + wholesaler_id + ")";
//    query.where = "wholesaler_id = " + wholesaler_id;
//     query.where = "wholesaler_id IN (1,2,3)";
    //execute query
    queryTask.execute(query,showResults);
function showResults(featureSet) {
    //remove all graphics on the maps graphics layer
    map.graphics.clear();
    //Performance enhancer - assign featureSet array to a single variable.
    var resultFeatures = featureSet.features;
    //Loop through each feature returned
    for (var i = 0, il = resultFeatures.length; i < il; i++) {
        //Get the current feature from the featureSet.
        //Feature is a graphic
        var graphic = resultFeatures;
        graphic.setSymbol(symbol);
        //Set the infoTemplate.
        graphic.setInfoTemplate(infoTemplate);
        //Add graphic to the map graphics layer.
        map.graphics.add(graphic);
</script>
</head>
<body>
<h1>SelecTree Web Map</h1>
Enter wholesaler_id (0, 1, 2, or 3):
  <input type="text" id="wholesaler_id" value="1,2,3">
  <input type="button" value="Get Nurseries" onclick="executeQueryTask(dojo.byId('wholesaler_id').value);">
  <div id="mapDiv" class="map"><div id="LocateButton"></div></div>
</body>
</html>
RobertScheitlin__GISP
Steve,
  You had several issues.
  1. Get away from using window.onload.
  2. Add html element listeners in the js code by using on.
  3. You were defining the map twice.
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #mapDiv,
    .map.container {
      padding: 20;
      margin: ;
      height: 650px;
      width: 650px;
    #LocateButton {
      position: absolute;
      top: 200px;
      left: 20px;
      z-index: 50;
  </style>
    // TODO
    // zoom to 50 miles
    var map;
    require([
      "esri/map",
      "esri/tasks/query",
      "dojo/_base/Color",
      "dojo/ready",
      "dojo/on",
      "dojo/_base/lang",
      "dojo/domReady!"
    ], function (
      Map, arcgisUtils, LocateButton, DynamicMapServiceLayer, ArcGISDynamicMapServiceLayer, Query, QueryTask,
      SimpleMarkerSymbol, InfoTemplate, Color, ready, on, lang) {
      var symbol = new SimpleMarkerSymbol();
      symbol.setSize(10);
      symbol.setColor(new Color([255, 255, 0, 0.5]));
      arcgisUtils.createMap("bf27abedb4dd4197b0fd2237a56d1555", "mapDiv").then(function (response) {
        map = response.map;
          map: map
        }, "LocateButton");
        executeQueryTask();
      //initialize query
      query.outFields = ["name", "street_address", "city", "state", "zip_code", "telephone", "website"];
      on(dojo.byId('queryBtn'), 'click', lang.hitch(this, function(){
        executeQueryTask();
        return (graphic.attributes.street_address + "<br/>" + graphic.attributes.city + ", " + graphic.attributes.state + " " + graphic.attributes.zip_code + "<br/>" + graphic.attributes.telephone + (String(graphic.attributes.website).length > 0 & graphic.attributes.website !== null ? "<br/><a href=\"" + graphic.attributes.website + "\" target=\"_blank\">website</a>" : " "));
      function executeQueryTask() {
        query.where = "wholesaler_id IN(" + dojo.byId('wholesaler_id').value + ")";
        //execute query
        queryTask.execute(query, showResults);
  </script>
</head>
<body>
  <h1>SelecTree Web Map</h1> Enter wholesaler_id (0, 1, 2, or 3):
  <input type="button" value="Get Nurseries" id="queryBtn">
  </div>
</body>
</html>
Steve,
   The locate button Dijit use HTML5 Geolocation abilities internally so there is no need to combine the two.
You can see this listed in the description of the locate button sample:
HTML5 Geolocation Position options for finding a location such as maximumAge and timeout.
StevePiercy1
Thanks, Robert. That solves half the problem. However, there is still an issue with combining dijit/LocateButton and QueryTask.
Here is the revised code.
<!DOCTYPE html>
<html>
<head>
<style>
html,body,#mapDiv,.map.container{
    padding:20;
    margin:;
    height:650px;
    width:650px;
#LocateButton {
    position: absolute;
    top: 200px;
    left: 20px;
    z-index: 50;
</style>
// TODO
// zoom to 50 miles
var map;
    require([
        "esri/map",
        "esri/tasks/query",
        "dojo/_base/Color",
        "dojo/ready",
        "dojo/domReady!"
        ], function(Map, arcgisUtils, LocateButton, DynamicMapServiceLayer, ArcGISDynamicMapServiceLayer, Query, QueryTask, SimpleMarkerSymbol, InfoTemplate, Color, ready){
            map = response.map;
        //initialize query
        symbol.setSize(10);
        // locate button
        map = new Map("mapDiv", {
            basemap: "streets",
            zoom: 10
            map: map
        }, "LocateButton");
    //execute query
</script>
</head>
<body>
</body>
</html>
If I comment out lines 112-120, then the nursery locations get plotted on the map via the QueryTask. If I leave those lines uncommented, then the LocateButton appears and works, but the nursery locations do not get plotted. Try pasting it into the sandbox to see what I mean.
Steve,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #mapDiv,
    .map.container {
      padding: 20;
      margin: ;
      height: 650px;
      width: 650px;
    #LocateButton {
      position: absolute;
      top: 200px;
      left: 20px;
      z-index: 50;
  </style>
    // TODO
    // zoom to 50 miles
    var map;
    require([
      "esri/map",
      "esri/tasks/query",
      "dojo/_base/Color",
      "dojo/ready",
      "dojo/on",
      "dojo/_base/lang",
      "dojo/domReady!"
    ], function (
      symbol.setSize(10);
        map = response.map;
          map: map
        }, "LocateButton");
        executeQueryTask();
      //initialize query
        executeQueryTask();
        //execute query
  </script>
</head>
<body>
  </div>
</body>
</html>
StevePiercy1
Thank you, Robert!
Here is the example on a test server...
Create a Web Map
...and integrated with the site.
http://selectree-test.nreswebserver.calpoly.edu/tree-detail/afrocarpus-falcatus
