Collect data from user using popop or infor Window
2630
7
01-08-2014 07:05 AM
JohnPreston
Hi, I would like the user to click on feature on map which opens a popup or info window where they enter in data. The data is then saved when user clicks button (or something). Is there a way to collect data this way? An example (or point me to an example) would be great, thanks!
JonathanUihlein
You could create a template for the infoWindow/Popup to generate an html5 form on feature selection.
I do something similar in a small app with html5 checkboxes and a submit data button on an infoWindow.
[ATTACH=CONFIG]30363[/ATTACH]
KenBuja
MVP Esteemed Contributor
Are you thinking of an application like this that uses the Attribute Inspector?
JohnPreston
It's close...I don't need to edit the layer, I want to save the data to a SQL database.
SteveCole
Honored Contributor
Jquery has a modal form which you might be able to use to collect your user's input. Dojo also has a Dialog Dijit that can serve the same purpose.
JohnPreston
Thanks Steve, I can easily create a popup using jquery to have the user enter data, what I liked about using a arcgis popup was that when you click on the map it may select more than one feature and the popup allows you to select the feature.
JonathanUihlein
JohnPreston
Thanks jon, That is what i am looking for. Do you have an exmple of code you could point me to?
JonathanUihlein
I wrote my own reusable dijit with accompanying template so it's a fairly complex sample to post on here.
Found some easier solutions that are less customizable but do nearly the same thing.
https://developers.arcgis.com/en/javascript/jssamples/widget_extendInfowindow.html
This sample uses a function to populate the content of the InfoWindow/Popup.
The function returns HTML that is then populated in each InfoWindow when a feature is selected.
Notice how a link ("Wikipedia Entry") is generated based on the feature selected.
https://developers.arcgis.com/en/javascript/jssamples/popup_chart.html
This sample uses the PopupTemplate class to customize the content of an InfoWindow/Popup.
Using PopupTemplate is quick but may not offer the ammount of customization you require.
(PopupTemplate Documentation: https://developers.arcgis.com/en/javascript/jsapi/popuptemplate-amd.html )
https://developers.arcgis.com/en/javascript/jssamples/fl_popup.html
This is an older sample (non-AMD) that is similar to the first sample but good for reference.
If these samples are too simple for your ultimate needs, you should explore writing your own dijit to replace Popup in the context of your application.
That's what I ended up having to do to.
