Coded Domain values when doing Query tasks
13719
38
10-19-2018 07:50 AM
Rocky_
Hello Friends, i saw lots of discussions on coded Domain values when doing Query tasks. But not a single is useful for me yet. I am having same question as you explain here. Can you please help me with the same for 4.9 API.
I am having 2 attributes with coded values..I want to add a drop down menu to selecting values for that specific attribute. So user can select specific value of that attribute and perform query task.
Right now am using below function..
Thank you.
let Status = new Query({
   returnGeometry: false,
   where: '1=1',
   returnDistinctValues: true,
   outFields: ['STATUS']
qTask1.execute(Status).then(function(results) {
      results.features.map(function(feat) {
      let opt5 = document.createElement('option');
      opt5.value = feat.attributes.STATUS;
      opt5.innerHTML = feat.attributes.STATUS;
      stadd.appendChild(opt5);
view.graphic.add(selectedGraphics);
let qSubtype = new Query({
   where: '1=1',
   outFields: ['SUBTYPE']
qTask72.execute(qSubtype).then(function(results) {
      let opt3 = document.createElement('option');
      opt3.value = feat.attributes.SUBTYPE;
      opt3.innerHTML = feat.attributes.SUBTYPE;
      subdd.appendChild(opt3);
RobertScheitlin__GISP
        pFL.queryFeatures(qUVp).then(function(results){
          arrayUtils.map(results.features, function(feat){
            let opt2 = document.createElement('option');
            opt2.value = feat.attributes.field1;
            const domain = pFL.getFieldDomain("field1", {feature: feat});
            opt2.innerHTML = domain.getName(feat.attributes.field1);
            peakdd.appendChild(opt2);
Don't forget to mark this as answered.
Rocky_
Sure Robert.. I never forget to mark ur answers.. just the thing is i cant able to solve issue ..I tried a lot to implement ur snippet in my code.. can you share me any other sample or fiddle.. its easy to understand more..
RAJ,
   I thought I gave you code to do exactly what you were asking for. Adding the description to a drop down so that you see the desc. but query on the actual value...
Rocky_
You trying to help me out from this situation. but the thing is, its my confusion about this two types.. Subtypes and Domain values.. I cant able to implement this in my actual code.. So am thinking if you have any workable samples, that you can share with me here.. So it becomes easier to understand me..
RAJ,
  It's a bit of work to put together a sample each time.
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>QueryTask - 4.9</title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
      overflow: hidden;
    #viewDiv.withGrid {
      height: 65%;
    .esri-widget {
      padding-left: 8px;
      padding-right: 4px;
    #paneDiv {
      position: absolute;
      top: 10px;
      left: 62px;
      padding: 0 12px 0 12px;
      background-color: rgba(0, 0, 0, 0.5);
      color: white;
    .info {
      line-height: 20px;
      padding-left: 5px ! important;
    .action-button {
      font-size: 16px;
      background-color: transparent;
      border: 1px solid #D3D3D3;
      color: #6e6e6e;
      height: 32px;
      width: 32px;
      text-align: center;
      box-shadow: 0 0 1px rgba(0, 0, 0, 0.3);
    .action-button:hover,
    .action-button:focus {
      background: #0079c1;
      color: #e4e4e4;
    .active {
      color: #e4e4e4;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.9/esri/css/main.css">
  <script src="https://js.arcgis.com/4.9/"></script>
  <script>
    let vlayerView;
    require([
        "esri/Map",
        "esri/views/MapView",
        "esri/widgets/Home",
        "esri/widgets/Legend",
        "esri/widgets/Search",
        "esri/layers/GraphicsLayer",
        "esri/layers/FeatureLayer",
        "esri/Graphic",
        "esri/widgets/Sketch/SketchViewModel",
        "esri/tasks/QueryTask",
        "esri/tasks/support/Query",
        "dojo/_base/array",
        "dojo/dom",
        "dojo/on",
        "dojo/dom-class",
        "dojo/domReady!"
      function(
        Map, MapView, Home, Legend, Search, GraphicsLayer, FeatureLayer, Graphic, SketchViewModel, QueryTask, Query, arrayUtils, dom, on,
        domClass
        let map, view, grid, editGraphic;
        const tempGraphicsLayer = new GraphicsLayer();
        let pUrl = "https://services.arcgis.com/V6ZHFr6zdgNZuVG0/ArcGIS/rest/services/2012_CA_NHTSA/FeatureServer/0";
        let pFL = new FeatureLayer({
          url: pUrl,
          outFields:['*']
        let qUVp= new Query({
          where: '1=1',
          outFields: ['sex'],
          orderByFields: ['sex ASC']
            opt2.value = feat.attributes.sex;
            opt2.innerHTML = pFL.getFeatureType(feat).name;
            sexdd.appendChild(opt2);
        // Define the popup content for each result
        const popupTemplate = { // autocasts as new PopupTemplate()
          title: "Accident Info",
          fieldInfos: [{
            fieldName: "atmcond",
            label: "Atmospheric Condition"
            fieldName: "numfatal",
            label: "Fatalities in Crash",
            format: {
              places: 0,
              digitSeperator: true
            fieldName: "conszone",
            label: "Work Zone"
            fieldName: "age",
            label: "Age",
            format: {
              places: 0,
            fieldName: "alcres",
            label: "Alcohol Test Results"
            fieldName: "sex",
            label: "Sex"
          content: "<b>Atmospheric Condition:</b> {atmcond}" +
            "<br><b>Prominence Rank:</b> {RANK}" +
            "<br><b>Fatalities in Crash:</b> {numfatal}" +
            "<br><b>Work Zone:</b> {conszone}" +
            "<br></b>Age:</b> {age}" +
            "<br></b>Alcohol Test Results:</b> {alcres}" +
            "<br></bSex:</b> {sex}"
        let resultsLayer = new GraphicsLayer();
        let qTask = new QueryTask({
          url: pUrl
        let params = new Query({
          returnGeometry: true
        map = new Map({
          basemap: "streets",
          layers: [resultsLayer, tempGraphicsLayer]
        view = new MapView({
          map: map,
          container: "viewDiv",
          zoom: 3,
          popup: {
            dockEnabled: true,
            dockOptions: {
              position: "top-right",
              breakpoint: false
        view.when(function() {
          view.ui.add("optionsDiv", "bottom-right");
          on(dom.byId("doBtn"), "click", doQuery);
          on(dom.byId("clrBtn"), "click", doClear);
          //Query to get unique vals
          let opt = document.createElement('option');
          opt.value = "";
          opt.innerHTML = "select Sex";
          sexdd.appendChild(opt);
        const sexdd = dom.byId("sexSelect");
        function doClear() {
          resultsLayer.removeAll();
        function doQuery() {
          doClear();
          // Clear the results from a previous query
          params.where = "sex = '" + sexdd.value + "'";
          if (tempGraphicsLayer.graphics.length > 0) {
            params.geometry = tempGraphicsLayer.graphics.getItemAt(0).geometry;
          params.outFields = ["*"];
          qTask.execute(params)
            .then(getResults)
            .catch(promiseRejected);
        function getResults(response) {
          let graphics = response.features;
          var RResults = arrayUtils.map(response.features, function(
            feature) {
            feature.symbol = {
              type: "simple-marker",
              color: "red",
              outline: {
                color: "black"
            feature.popupTemplate = popupTemplate;
            return feature;
          resultsLayer.addMany(RResults);
          view.goTo(RResults);
        function promiseRejected(error) {
          console.error("Promise rejected: ", error.message);
        var homeBtn = new Home({
          view: view
        }, "homeDiv");
        var legend = new Legend({
          view: view,
          layerInfos: [{
            url: pUrl
        legend.startup();
        view.ui.add(legend, "bottom-left");
        var searchWidget = new Search({
          view: view
        view.ui.add(searchWidget, {
          // create a new sketch view model
          const sketchViewModel = new SketchViewModel({
            view: view,
            layer: tempGraphicsLayer,
            pointSymbol: {
              type: "simple-marker", // autocasts as new SimpleMarkerSymbol()
              style: "square",
              color: "#8A2BE2",
              outline: { // autocasts as new SimpleLineSymbol()
                color: [255, 255, 255],
                width: 3
            polylineSymbol: {
              type: "simple-line", // autocasts as new SimpleLineSymbol()
              color: "#8A2BE2",
              width: "4",
              style: "dash"
            polygonSymbol: {
              type: "simple-fill", // autocasts as new SimpleFillSymbol()
              color: "rgba(138,43,226, 0.8)",
              style: "solid",
              outline: {
                color: "white",
                width: 1
          setUpClickHandler();
          // Listen to create-complete event to add a newly created graphic to view
          sketchViewModel.on("create-complete", addGraphic);
          // Listen the sketchViewModel's update-complete and update-cancel events
          sketchViewModel.on("update-complete", updateGraphic);
          sketchViewModel.on("update-cancel", updateGraphic);
          // called when sketchViewModel's create-complete event is fired.
          function addGraphic(event) {
            // Create a new graphic and set its geometry to
            // `create-complete` event geometry.
            const graphic = new Graphic({
              geometry: event.geometry,
              symbol: sketchViewModel.graphic.symbol
            tempGraphicsLayer.add(graphic);
          // called when sketchViewModel's update-complete or update-cancel
          // events are fired.
          function updateGraphic(event) {
            // event.graphic is the graphic that user clicked on and its geometry
            // has not been changed. Update its geometry and add it to the layer
            event.graphic.geometry = event.geometry;
            tempGraphicsLayer.add(event.graphic);
            // set the editGraphic to null update is complete or cancelled.
            editGraphic = null;
          // set up logic to handle geometry update and reflect the update on "tempGraphicsLayer"
          function setUpClickHandler() {
            view.on("click", function(event) {
              view.hitTest(event).then(function(response) {
                var results = response.results;
                // Found a valid graphic
                if (results.length && results[results.length - 1]
                  .graphic) {
                  // Check if we're already editing a graphic
                  if (!editGraphic) {
                    // Save a reference to the graphic we intend to update
                    editGraphic = results[results.length - 1].graphic;
                    // Remove the graphic from the GraphicsLayer
                    // Sketch will handle displaying the graphic while being updated
                    tempGraphicsLayer.remove(editGraphic);
                    sketchViewModel.update(editGraphic);
          // activate the sketch to create a point
          var drawPointButton = document.getElementById("pointButton");
          drawPointButton.onclick = function() {
            // set the sketch to create a point geometry
            sketchViewModel.create("point");
            setActiveButton(this);
          // activate the sketch to create a polyline
          var drawLineButton = document.getElementById("polylineButton");
          drawLineButton.onclick = function() {
            // set the sketch to create a polyline geometry
            sketchViewModel.create("polyline");
          // activate the sketch to create a polygon
          var drawPolygonButton = document.getElementById("polygonButton");
          drawPolygonButton.onclick = function() {
            // set the sketch to create a polygon geometry
            sketchViewModel.create("polygon");
          // activate the sketch to create a rectangle
          var drawRectangleButton = document.getElementById(
            "rectangleButton");
          drawRectangleButton.onclick = function() {
            sketchViewModel.create("rectangle");
          // activate the sketch to create a circle
          var drawCircleButton = document.getElementById("circleButton");
          drawCircleButton.onclick = function() {
            sketchViewModel.create("circle");
          // reset button
          document.getElementById("resetBtn").onclick = function() {
            sketchViewModel.reset();
            tempGraphicsLayer.removeAll();
            setActiveButton();
          function setActiveButton(selectedButton) {
            // focus the view to activate keyboard shortcuts for sketching
            view.focus();
            var elements = document.getElementsByClassName("active");
            for (var i = 0; i < elements.length; i++) {
              elements[i].classList.remove("active");
            if (selectedButton) {
              selectedButton.classList.add("active");
  </script>
</head>
<body>
  <div id="viewDiv">
    <div class="esri-widget" id="optionsDiv">
      <h2>Fatal Accidents in California by Sex</h2>
      <select class="esri-widget" id="sexSelect"></select>
      <br>
      <br>
      <div id="topbar">
        <button class="action-button esri-icon-blank-map-pin" id="pointButton" type="button" title="Draw point"></button>
        <button class="action-button esri-icon-polyline" id="polylineButton" type="button" title="Draw polyline"></button>
        <button class="action-button esri-icon-polygon" id="polygonButton" type="button" title="Draw polygon"></button>
        <button class="action-button esri-icon-checkbox-unchecked" id="rectangleButton" type="button" title="Draw rectangle"></button>
        <button class="action-button esri-icon-radio-unchecked" id="circleButton" type="button" title="Draw circle"></button>
        <button class="action-button esri-icon-trash" id="resetBtn" type="button" title="Clear graphics"></button>
      </div>
      <br>
      <button class="esri-widget" id="doBtn">Do Query</button>
      <button class="esri-widget" id="clrBtn">Clear</button>
      <br>
      <br>
    </div>
  </div>
</body>
</html>
Rocky_
Sorry for inconvenience Robert. but you are the one only person who knows ARCGIS JS more better than anyone else i know.. You are the most experienced person cause, i think all these complicated issues you faced in past already..
I am rookie in ArcGIS...
and I really appreciate your help Robert.
Thank You so Much..
Rocky_
Hi Robert, can i get your personal mailId..
No I do not give that out as I would be bombarded with people asking for development help.
Rocky_
Ok.. I can understand. am not asking you anything weird on mail.. You have a good command on ArcGIS javascript so want to be your assistant (guide me to be Pro in ArcGIS) ...
