Closing the infoWindow produces a map click on mobile
878
06-06-2014 10:05 AM
MikeKissane
The application I am working has an infoWindow that is created when an address is searched for and the same query can be ran by clicking on a parcel on the map.  Everything works great except when it used on a mobile device either Android or iPhone.  When the infoWindow is closed selecting the X it also clicks the map and runs the query for the parcel under the X.  How can a prevent the map from being clicked when the infoWindow is closed?
You can check out the application here:
http://www.talgov.com/gis/underground/default.aspx
You can use "300 S Adams St" for a sample address.
This is using the ESRI bootstrap template on GitHub.
