ClosestFacilityTask Not Working
1817
05-08-2013 03:23 PM
JordanParfitt
I'm new to this but my ClosestFacilityTask isn't working. I can't find a working example online so I'm not sure what I'm doing wrong. I don't get an error but it isn't firing off in Fiddler either. Any help?
Thanks in Advance.
    dojo.connect(gsvc, "onBufferComplete", function (geometries) {
        var facilities = new esri.tasks.FeatureSet();
        facilities.features = [new esri.Graphic(geometries[0])]; ;
        var params = new esri.tasks.ClosestFacilityParameters();
        params.facilities = facilities;
        params.outSpatialReference = map.spatialReference;
        var closestFacilityTask = new esri.tasks.ClosestFacilityTask("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Network/USA/NAServer/Closest Facility")
        closestFacilityTask.solve(params, function (solveResult) {
            alert('success');
derekswingley1
If you post a more complete code sample to reproduce your problem we can provide more help. It's hard to say what's going wrong with the code you posted.
Here's a sample that shows how to use the closest facility task:  http://developers.arcgis.com/en/javascript/jssamples/routetask_closest_facility.html
JordanParfitt
Here is my complete code:
function mapClickHandler(evt) {
    //build query
    var queryTask = new esri.tasks.QueryTask("http://192.168.7.114/arcgis/rest/services/FiberNet/Base/MapServer/0");
    var incidents = new esri.tasks.FeatureSet();
    incidents.features = [new esri.Graphic(new esri.geometry.Point(evt.mapPoint.x, evt.mapPoint.y, map.spatialReference))];
    //build query filter
    var query = new esri.tasks.Query();
    query.where = "1=1";
    query.returnGeometry = true;
    query.outFields = ["*"];
    queryTask.execute(query, function (queryResult) {
        facilities.features.push(new esri.Graphic(new esri.geometry.Point(-13625960, 4549921, map.spatialReference)));
       //facilities.features = queryResult.features;
        params.defaultCutoff = 3.0;
        params.returnIncidents = false;
        params.returnRoutes = true;
        params.returnDirections = true;
        params.incidents = incidents;
        //solve
            var directions = solveResult.directions;
            dojo.forEach(solveResult.routes, function (route, index) {
                //build an array of route info
                var attr = dojo.map(solveResult.directions[index].features, function (feature) {
                    return feature.attributes.text;
                routeGraphicLayer.add(route);
                dojo.byId("directionsDiv").innerHTML = "Hover over the route to view directions";
It works when I use:
It breaks when I use:
I'm not getting an error... the task never even fires off in fiddler. I've tried looping through and adding them to the array manually it still never fires
JordanParfitt
It breaks when I upload more than 10 facilities.
JordanParfitt
Does ArcGIS publish a 10.1 service I can try?
