Close infoWindow with ESC key?
3919
06-26-2011 11:08 PM
StephenLead
Honored Contributor
Has anyone implemented a listener to close the infoWindow when the ESC key is pressed?
If so are you able to share the code, so I don't reinvent the wheel?
Steve
HemingZhu
Steve
Though i have not done this, it should be straightforward. Something like this.
dojo.connect (map, "onKeyDown", function (key){ if (key.keyCode == 27) { map.infoWindow.hide(); } }); //ESC keyCode =27. keyCode =0 means no key press
derekswingley1
Nice one hzhu! Now, what do I need to do to get you to start using code tags? 😉
DanielYim
As the Internet moves to the "Web 3.0" paradigm, I think it's almost necessary to incorporate the keyboard as a part of my mapping applications. So personally, I use Shortcuts.js to handle the mapping of all of my keyboard shortcuts.
It's as simple as adding this to your HTML:
<script type="text/javascript" src="shortcuts.js"></script>
And then adding the following to your Javascript's init or dojo.addOnLoad:
    // Define some keyboard shortcuts
    var kbdOptions = {
        disable_in_input: true,
        propagate: false
    shortcut.add("Escape", function() {
        N.myMap.infoWindow.hide();
    }, kbdOptions);
Other examples: I use F for full extent, I for the identify tool, Q and W for prev/next extent.
It really helps the powerusers out there make the most out of your application, without them needing to fumble around with toolbars.
StephenLead
Honored Contributor
Daniel, this is great - thanks
