Classification field
1940
12-27-2012 10:47 AM
SamirGambhir
My GenerateRendererTask generates a renderer and lists the class break in a legend div. The numbers in the class breaks are unformatted. Is there a way to programmatically format these numbers e.g. instead of 8.808848 - 17.767013, I should see 8.81 - 17.77?
I am using Arcgis Server 10.1 with Javascript API.
Thanks
Samir
JeffPace
my guess is just prior to
stateFeatureLayer.setRenderer(renderer);
you will have to evaluate and modify the renderer
from classbreaksrenderer API
var symbols = dojo.map(results[0].layer.renderer.infos,function(info){
  return  {label: info.label,symbol:info.symbol};
seems to indicate that you could override the label with a rounded value
JeffPace
Thanks
Samir
have you tried
dojo.number.format(value, {places:2});
SamirGambhir
have you tried
Thanks Jeff,
I am not sure where to put this function. Please look at the example in this post and suggest where can I add this function.
Samir
JeffPace
SamirGambhir
Thanks, Jeff, for your help. It worked!
Samir
JeffPace
awesome happy to help!
