Check Topology in JavaScript?
6473
18
03-05-2018 12:30 PM
ShaningYu
Honored Contributor
Does current JS API provides topology functions?  Thanks.
ShaningYu
Honored Contributor
selected_Poly = response.features.geometry; //.rings[0];
var polygonSymbol = new esri.symbol.SimpleFillSymbol(
   esri.symbol.SimpleFillSymbol.STYLE_SOLID, // or "solid",
   new esri.symbol.SimpleLineSymbol("solid", new esri.Color([232, 104, 80]), 2),
   new esri.Color([232, 104, 80, 0.25])
var graphic = new esri.Graphic(selected_Poly, polygonSymbol);  // got attributes, geometry, and symbol null value; what is wrong here?  Thanks.
graphic.setSymbol(polygonSymbol);
ShaningYu
Honored Contributor
also  in debugging
selected_Poly.contains(new esri.geometry.Point([-76.99, 38.88]))
got     Object doesn't support property or method 'contains'
where
selected_ContractSection.rings
[-8574575.3238,4706898.530699998,-8574717.6555,4706897.306000002,-8574736.575,4706897.310400002,-8575245.9761,4706912.5276999995,-8575227.622,4707114.234399997,-8575227.5562,4707119.869999997,-8575219.9439,4707238.998999998,-8574736.4339,4707222.973899998,-8574717.4695,4707222.967699997,-8574503.5524,4707224.6489999965,-8574507.9585,4707120.172899999,-8574507.9603,4707114.672899999,-8574535.2586,4706976.1853,-8574575.3238,4706898.530699998]
__proto__: []
length: 1
[0]: [...]
RobertScheitlin__GISP
Shaning,
   Can you check the instance of selected_Poly using this code?
console.log(selected_Poly instanceof esri.geometry.Polygon);
Should come back as true.
ShaningYu
Honored Contributor
Got  selected_Poly != esri.geometry.Polygon.  The I tried
var ar2D = new Array();
for (var j=0; j < selected_Poly.length; j++) {
  var ar1D = [ selected_Poly[0], selected_Poly[1] ];
    ar2D.push(ar1D);
polygon = new esri.geometry.Polygon();
polygon.addRing(ar2D);
Then, I checked the polygon object:
polygon
_ring: 0
cache: undefined
rings: [-8574575.3238,4706898.530699998,-8574717.6555,4706897.306000002,......]
spatialReference: {...}
type: "polygon"
However, still get
polygon.geometry != esri.geometry.Polygon
What's wrong in my code?  Thanks.
Shaning,
   What is the WKID of your data?
ShaningYu
Honored Contributor
wkid=102100
Shaning,
   You are still using Legacy style of coding verses AMD which is what you really should be using in today's day and age (Legacy style of coding is not even supported in JS 4.x api). Here is a very simple sample that shows the contains method. Also you will notice that I have used some of your polygon coordinates with wkid 102100 and they do not plot on the map. So I am not sure your data is 102100.
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Polygon Contains</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.23/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="https://js.arcgis.com/3.23/esri/css/esri.css">
    <style>
      html, body, #map {
        height:100%;
        margin: 0;
        padding: 0;
        width:100%;
        overflow:hidden;
    </style>
    <script src="https://js.arcgis.com/3.23/"></script>
    <script>
      var map, editToolbar, ctxMenuForGraphics, ctxMenuForMap;
      var selected, currentLocation;
      require([
        "esri/map", "esri/geometry/Point", "esri/geometry/Polygon",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
        "esri/graphic",
        "esri/Color",
        "esri/tasks/query", "esri/tasks/QueryTask",
        "dojo/domReady!"
      ], function(
        Map, Point, Polygon,
        SimpleLineSymbol,
        SimpleFillSymbol,
        Graphic,
        Color,
        query,
        QueryTask
        map = new Map("map", {
          basemap: "satellite",
          center: [20.039, 62.739],
          zoom: 3
        map.on("load", addGraphics);
        function addGraphics() {
          // Adds pre-defined geometries to map
          var polygonSymbol = new SimpleFillSymbol(
            new SimpleLineSymbol(
              SimpleLineSymbol.STYLE_DOT,
              new Color([151, 249, 0, 0.8]),
            new Color([151, 249, 0, 0.45])
          var polygon = new Polygon({
            "rings": [
                [-4226661.916056009, 8496372.808143634],
                [-3835304.3312360067, 8731187.359035634],
                [-2269873.991956003, 9005137.668409634],
                [-1213208.5129420012, 8613780.083589634],
                [-1017529.7205320001, 8065879.464841632],
                [-1213208.5129420012, 7478843.087611631],
                [-2230738.233474003, 6891806.710381631],
                [-2935181.8861500043, 6735263.6764536295],
                [-3522218.263380006, 6891806.710381631],
                [-3952711.606682008, 7165757.01975563],
                [-4265797.674538009, 7283164.295201631],
                [-4304933.433020009, 7635386.121539632],
                [-4304933.433020009, 7674521.880021632],
            "spatialReference": {
              "wkid": 102100
          var spolygon = new Polygon({
            "rings": [
                [-8574575.3238, 4706898.530699998],
                [-8574717.6555, 4706897.306000002],
                [-8574736.575, 4706897.310400002],
                [-8575245.9761, 4706912.5276999995],
                [-8575227.622, 4707114.234399997],
                [-8575227.5562, 4707119.869999997],
                [-8575219.9439, 4707238.998999998],
                [-8574736.4339, 4707222.973899998],
                [-8574717.4695, 4707222.967699997],
                [-8574503.5524, 4707224.6489999965],
                [-8574507.9585, 4707120.172899999],
                [-8574507.9603, 4707114.672899999],
                [-8574535.2586, 4706976.1853],
              "wkid": 102100
          map.graphics.add(new Graphic(polygon, polygonSymbol));
          map.graphics.add(new Graphic(spolygon, polygonSymbol));
          console.info(polygon.contains(new Point([-76.99, 38.88])));
    </script>
  </head>
  <body class="claro">
      <div id="map"></div>
  </body>
</html>
ShaningYu
Honored Contributor
GREAT HELP!  Thanks a LOT!!!
ShaningYu
Honored Contributor
Rebert:  Got an additional prob. (see my email to you).  Could you take a look?  Thanks.
