Change the togglebasemap title
4800
6
06-17-2016 01:48 AM
Pierre-JeanMuller
I want to change the togglebasemap titles. I tried with the basemaps object, but it doesn't work.
RobertScheitlin__GISP
Pierre,
  Here is a sample of how to apply custom basemap names:
<!DOCTYPE HTML>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <title>Basemap Toggle</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.16/esri/css/esri.css">
  <style>
    html, body, #map {
      padding:0;
      margin:0;
      height:100%;
    #BasemapToggle {
      position: absolute;
      top: 20px;
      right: 20px;
      z-index: 50;
  </style>
  <script src="http://js.arcgis.com/3.16/"></script>
  <script>
var map;
    require([
      "esri/map",
      "esri/dijit/BasemapToggle",
      "esri/dijit/Basemap",
      "esri/dijit/BasemapLayer",
      "esri/geometry/Extent",
      "esri/basemaps",
      "dojo/domReady!"
    ], function(
      Map,
      BasemapToggle,
      Basemap,
      BasemapLayer,
      Extent,
      esriBasemaps
      map = new Map("map", {
        basemap: 'streets'
      var toggle = new BasemapToggle({
        map: map,
        basemap: "topo",
        basemaps:{
          "streets":{
            "title":"Streets 777",
            "thumbnailUrl":"https://js.arcgis.com/3.16/esri/images/basemap/streets.jpg"
          "topo":{
            "title":"Topography 777",
            "thumbnailUrl":"https://js.arcgis.com/3.16/esri/images/basemap/topo.jpg"
      }, "BasemapToggle");
      toggle.startup();
  </script>
</head>
<body>
  <div id="map" class="map">
    <div id="BasemapToggle"></div>
  </div>
</body>
</html>
FC_Basson
Which version of the API?  3.x or 4.0?
Pierre-JeanMuller
api 3.16
FC_Basson
I assume you are referring to the Widget title text (Switch Basemap) then.
Specify an id attribute for the TitlePane div:
<div id="basemapTitle" data-dojo-type="dijit/TitlePane"  data-dojo-props="title:'Switch Basemap', closable:false, open:false">
Then with dijit set the new title:
dijit.byId("basemapTtile").set("title", "My new awesome title");
Pierre-JeanMuller
thanks for your answer, but what I want is to change the texte under the basemap name. For example : in the image, I want to change "Topographie" to "Topography"
Pierre,
<!DOCTYPE HTML>
<html>
<head>
  <style>
    html, body, #map {
      padding:0;
      margin:0;
      height:100%;
    #BasemapToggle {
      position: absolute;
      top: 20px;
      right: 20px;
      z-index: 50;
  </style>
  <script>
var map;
    require([
      "esri/map",
      "esri/basemaps",
      "dojo/domReady!"
    ], function(
      Map,
      BasemapToggle,
      Basemap,
      BasemapLayer,
      Extent,
      esriBasemaps
        basemap: 'streets'
        map: map,
        basemap: "topo",
        basemaps:{
          "streets":{
          "topo":{
      toggle.startup();
  </script>
</head>
<body>
  </div>
</body>
</html>
SteveCole
Honored Contributor
I think another option is modifying the default string used by the API. This link discusses that topic. If you follow the suggestion at the bottom of that page, you'll notice that there's a "basemaps" object and I think you'd be able to modify the label/string in there.
Steve
