Change popup background or title bar color dynamically
1238
04-03-2013 04:46 AM
by Anonymous User
Not applicable
Original User: abalder
I have three different types of data that are symbolized by three different colors. I would like to have the popup�??s background or title bar color change corresponding to the type of data the user clicks on. For example if the user clicks on a green point I want the background or title bar of the popup to be green. I understand I can change these items via CSS but how does one go about doing this on the fly?
ShadCampbell
You can dynamically add and remove css classes to elements with dojo...
require(["dojo/dom-class"], function(domClass){
    // Add a class to some node:
    domClass.add("someNode", "newClass");
or to remove...
domClass.remove("someNode", "someClass");
Perhaps set these prior to the setFeatures method?  Not sure exactly...
-Shad
