Change default of identified feature
4786
01-11-2016 11:21 AM
JohnPreston
Hi, I am using IdentifyTask with map.onclick then display attributes in a popup. Everything works great, however I would like to change the default color of found feature (right now it is default to a cyan). How can I do that?
var deferred = identifyTask
.execute(identifyParams)
.addCallback(function (response) {
     return arrayUtils.map(response, function (result) {
     var feature = result.feature;
     var layerName = result.layerName;
     var idTemplate = new InfoTemplate();
     idTemplate.setContent("Parcel ID:" + feature.attributes['PID_NUM'] + "
" +                                                 "Address:" + feature.attributes['site_address'] + "
" +                                                 "Owner:" + feature.attributes['owner_name'] + ");
idTemplate.setTitle("Parcel");
feature.setInfoTemplate(idTemplate);
return feature;
map.infoWindow.setFeatures([deferred]);
map.infoWindow.show(evt.mapPoint);
RobertScheitlin__GISP
John,
   The maps InfoWindow use PopUp dijit by default and the link I provided to to the properties of the PopUp dijit. Something as simple as:
map.infoWindow.markerSymbol = new MarkerSymbol();
John,
   You set the markerSymbol or lineSymbol or fillSymbol on the map.infoWindow
Ryan_Galbraith
Thanks for that - I was just working on something very similar.
JohnPreston
Thank you Robert,
Do you have an example? I don't see those properties for map.infoWindow
John
John,
JohnPreston
Perfect! Thank you!
