Cant edit polyline with m value
3137
06-25-2016 03:54 AM
Haider_Ali
Greetings,
          I am using Edit rivers and waterbodies  sample with my polyline feature layer(m enabled), the problem is i cant edit the vertices or move the polyline i can only change the attributes of the feature. if i use the same sample which is not m enabled the sample is working fine. Also i noted that if i double click the feature sometimes it disappears, I have to pan the map or zoom in/out  to see the feature again  is it a bug?
Regards,
Haider
BillDaigle
I haven't tried this, but I'm not too surprised you're having trouble editing your m-enabled features.  The JavaScript API doesn't really have anything built in to deal with m or z values.  I talked with a developer about this at the Dev Summit -- they are hoping to incorporate z and m capabilities at 4.x.
Haider_Ali
That is  why i'm surprised  too , why editor widget is stopping me from editing the geometry of  polyline feature.
