CAnnot get HomeButton to appear
918
05-05-2014 01:49 PM
by Anonymous User
Not applicable
Original User: mmestrov
I'm trying to add a home button to my web site. I follow the example on the developer site, but no button shows up.  Looking for some help in what I'm doing wrong.
Code is attached.
by Anonymous User
Not applicable
Original User: craygo
From what I can see, your homebutton div is inside the map div which will put it behind your map. 2 things you can do, move it outside the map div or add a z-index to bring it to the top.
Option 1
[HTML]
        <div id="HomeButton"></div>
        <div data-dojo-type="dijit/layout/ContentPane" id="map" class="map"
            data-dojo-props="region:'center'" style="border: medium solid #808080">
            <!-- Bookmarks widget inside a Drop Down Button -->
            <div id="bookmarks-wrapper">
                <div data-dojo-type="dijit.form.DropDownButton">
                    <span>Fire Districts</span>
                    <div data-dojo-type="dijit.TooltipDialog">
                        <div id="bookmarksFire"></div>
                    </div>
                </div>
            </div>
        </div>
[/HTML]
Option 2
[HTML]
            <div id="HomeButton" style="z-index:9999;"></div>
                    </div>
                </div>
            </div>
        </div>
[/HTML]
Try that
Ray
