Cannot edit sketch vertex that goes off screen
1015
01-19-2022 01:42 PM
ironmaskito
In the picture you can see that I have made one of the vertices go off map while sketching in a mapview. When I completed the drawing, I'm not able to drag the vertex on the left that went off map. However, if I drag the map to the left so that both vertices appear to be connected, I am able to drag both vertices again. Is this a bug with esri? I am not getting any console errors. I don't have the same issue when sketching in sceneview.
JoseBanuelos
Hello @ironmaskito ,
Could you provide a simplified reproducible app? I was not able to reproduce this with the sketch-geometries sample.
Jose
