Can you use a points feature class in attribute inspector? Mine are not working.
3345
5
12-05-2014 01:51 PM
RobertKirkwood
<!DOCTYPE html>
<html>
  <head>
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <title>Editable FeatureLayer in Selection Only Mode with Attribute Inspector</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
    <style>
      html, body {
        height: 100%; width: 100%;
        margin: 0;
        padding: 0;
        overflow: hidden;
      #mapDiv{
        margin: 0;
        padding:0;
      #detailPane{
        height:20px;
        color:#570026;
        font-size:12pt;
        font-weight:600;
        overflow:hidden;
      .dj_ie .infowindow .window .top .right .user .content { position: relative; }
      .dj_ie .simpleInfoWindow .content {position: relative;}
      .esriAttributeInspector {height:100px;}
      .esriAttributeInspector .atiLayerName {display:none;}
      .saveButton {
        padding-left:45px;
         margin:0px;width:16px; height:16px;
    </style>
    <script src="http://js.arcgis.com/3.11/"></script>
    <script>
      var map;
      var updateFeature;
      require([
        "esri/map",
        "esri/layers/FeatureLayer",
        "esri/dijit/AttributeInspector",
         "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
        "esri/Color",
        "esri/layers/ArcGISDynamicMapServiceLayer",
        "esri/config",
        "esri/tasks/query",
        "dojo/parser",
        "dojo/dom-construct",
        "dijit/form/Button",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
      ], function(
        Map, FeatureLayer, AttributeInspector, SimpleMarkerSymbol,
        SimpleLineSymbol, SimpleFillSymbol, Color,
        ArcGISDynamicMapServiceLayer, esriConfig,
        Query,
        parser, domConstruct, Button
        parser.parse();
        // refer to "Using the Proxy Page" for more information:  https://developers.arcgis.com/javascript/jshelp/ags_proxy.html
        //esriConfig.defaults.io.proxyUrl = "/proxy/";
        map = new Map("mapDiv", {
          basemap: "topo",
                    center: [-107.646372, 43.433484],
                    zoom: 7
        map.on("layers-add-result", initSelectToolbar);
        var petroFieldsMSL = new ArcGISDynamicMapServiceLayer("https://wygiscservices-dev.wygisc.org/arcgis/rest/services/WyoBio/WyoBioMobile/MapServer");
        petroFieldsMSL.setDisableClientCaching(true);
        map.addLayer(petroFieldsMSL);
        var petroFieldsFL = new FeatureLayer("https://wygiscservices-dev.wygisc.org/arcgis/rest/services/WyoBio/WyoBioMobile/FeatureServer/0",
                            mode: FeatureLayer.MODE_SELECTION,
                            outFields: ["*"]
        var selectionSymbol = new SimpleFillSymbol(
            SimpleFillSymbol.STYLE_NULL,
            new SimpleLineSymbol(
                "solid",
                new Color("yellow"),
            null
        petroFieldsFL.setSelectionSymbol(selectionSymbol);
        petroFieldsFL.on("edits-complete", function() {
          petroFieldsMSL.refresh();
        map.addLayers([petroFieldsFL]);
        function initSelectToolbar(evt) {
          var petroFieldsFL = evt.layers[0].layer;
          var selectQuery = new Query();
          map.on("click", function(evt) {
            selectQuery.geometry = evt.mapPoint;
            petroFieldsFL.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW, function(features) {
              if (features.length > 0) {
                //store the current feature
                updateFeature = features[0];
                map.infoWindow.setTitle(features[0].getLayer().name);
                map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint));
              else {
                map.infoWindow.hide();
          map.infoWindow.on("hide", function() {
            petroFieldsFL.clearSelection();
          var layerInfos = [
              'featureLayer': petroFieldsFL,
              'showAttachments': true,
              'isEditable': true,
              'fieldInfos': [
                {'fieldName': 'HabDesc_', 'isEditable': true, 'tooltip': 'Current Status', 'label': 'Status:'},
                {'fieldName': 'WeatherConditions_', 'isEditable': true, 'tooltip': 'The name of this oil field', 'label': 'Field Name:'}
          var attInspector = new AttributeInspector({
            layerInfos: layerInfos
          }, domConstruct.create("div"));
          //add a save button next to the delete button
          var saveButton = new Button({ label: "Save", "class": "saveButton"});
          domConstruct.place(saveButton.domNode, attInspector.deleteBtn.domNode, "after");
          saveButton.on("click", function() {
            updateFeature.getLayer().applyEdits(null, [updateFeature], null);
          attInspector.on("attribute-change", function(evt) {
            //store the updates to apply when the save button is clicked
            updateFeature.attributes[evt.fieldName] = evt.fieldValue;
          attInspector.on("next", function(evt) {
            updateFeature = evt.feature;
            console.log("Next " + updateFeature.attributes.objectid);
          attInspector.on("delete", function(evt) {
            evt.feature.getLayer().applyEdits(null, null, [evt.feature]);
          map.infoWindow.setContent(attInspector.domNode);
          map.infoWindow.resize(350, 240);
    </script>
  </head>
  <body class="claro">
    <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width:100%;height:100%;">
      <div id="detailPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'">
        Click a field to display the attribute inspector with customized fields.
      </div>
      <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" id="mapDiv"></div>
    </div>
  </body>
</html>
Tags (1)
KellyHutchins
Esri Notable Contributor
Robert,
The sample you are using uses the clicked location to query for a geometry in the feature layer. This works fine for polygons but for points or lines you'll need to buffer the click point a bit in order to use it as the query geometry. Here's a revised version of your sample that includes additional logic in the map click event to create a buffer around the click point.
<!DOCTYPE html>
<html>
  <head>
      on iOS devices-->
    <style>
      html, body {
        margin: 0;
        padding: 0;
        overflow: hidden;
      #mapDiv{
        margin: 0;
        padding:0;
      #detailPane{
        height:20px;
        color:#570026;
        font-size:12pt;
        font-weight:600;
        overflow:hidden;
      .saveButton {
        padding-left:45px;
    </style>
    <script>
      var map;
      var updateFeature;
      require([
        "esri/map",
        "esri/Color",
        "esri/config",
        "esri/tasks/query",
        "esri/geometry/Extent",
        "dojo/parser",
      ], function(
        Query,Extent,
        parser.parse();
          basemap: "topo",
                    zoom: 7
                            outFields: ["*"]
                "solid",
            null
            var mapWidth = map.extent.getWidth();
            //Divide width in map units by width in pixels
            var pixelWidth = mapWidth/map.width;
            //Calculate a 10 pixel envelope width (5 pixel tolerance on each side)
            var tolerance = 10 * pixelWidth;
            //Build tolerance envelope and set it as the query geometry
            var queryExtent  = new esri.geometry.Extent
                (1,1,tolerance,tolerance,evt.mapPoint.spatialReference);
            selectQuery.geometry = queryExtent.centerAt(evt.mapPoint);
            //selectQuery.geometry = evt.mapPoint.extent.expand(2);
              else {
          var layerInfos = [
              'isEditable': true,
              'fieldInfos': [
          console.log("Att");
    </script>
  </head>
      </div>
    </div>
  </body>
</html>
KellyHutchins
Yes points are supported with the attribute inspector. Do you get any errors when you run your application? If you haven't done so already try running your application with browser debugging tools (like Chrome Developer Tools) open and see if any error messages are written to the console.
RobertKirkwood
Kelly,
I am not getting any errors. I thought i posted my code above but do not see it...I will try again.
RobertKirkwood
<!DOCTYPE html>
<html>
  <head>
      on iOS devices-->
    <style>
      html, body {
        margin: 0;
        padding: 0;
        overflow: hidden;
      #mapDiv{
        margin: 0;
        padding:0;
      #detailPane{
        height:20px;
        color:#570026;
        font-size:12pt;
        font-weight:600;
        overflow:hidden;
      .saveButton {
        padding-left:45px;
    </style>
    <script>
      var map;
      var updateFeature;
      require([
        "esri/map",
        "esri/Color",
        "esri/config",
        "esri/tasks/query",
        "dojo/parser",
      ], function(
        Query,
        parser.parse();
          basemap: "topo",
                    zoom: 7
                            outFields: ["*"]
                "solid",
            null
              else {
          var layerInfos = [
              'isEditable': true,
              'fieldInfos': [
    </script>
  </head>
      </div>
    </div>
  </body>
</html>
KellyHutchins
Robert,
<!DOCTYPE html>
<html>
  <head>
      on iOS devices-->
    <style>
      html, body {
        margin: 0;
        padding: 0;
        overflow: hidden;
      #mapDiv{
        margin: 0;
        padding:0;
      #detailPane{
        height:20px;
        color:#570026;
        font-size:12pt;
        font-weight:600;
        overflow:hidden;
      .saveButton {
        padding-left:45px;
    </style>
    <script>
      var map;
      var updateFeature;
      require([
        "esri/map",
        "esri/Color",
        "esri/config",
        "esri/tasks/query",
        "dojo/parser",
      ], function(
        Query,Extent,
        parser.parse();
          basemap: "topo",
                    zoom: 7
                            outFields: ["*"]
                "solid",
            null
              else {
          var layerInfos = [
              'isEditable': true,
              'fieldInfos': [
          console.log("Att");
    </script>
  </head>
      </div>
    </div>
  </body>
</html>
RobertKirkwood
Thanks so much again! This made my day!
