Can we pass the map service (REST) URL as a URL parameter to the JS API map template?
2854
8
07-26-2011 11:02 AM
DonBarker
The ArcGIS.com (Javascript) viewer accepts a map service (REST) URL as a URL parameter, like this:
http://www.arcgis.com/home/webmap/viewer.html?url=http%3a%2f%2f129.2.24.163%2fArcGIS%2frest%2fservic...
When I try this with my locally-hosted JS API map template, nothing appears.
Don
DonBarker
Derek,
Thanks for taking time to reply.
But my question is about passing in the REST URL as a parameter, rather than the unique id of an AGO web map.
Don
DonBarker
Derek,
But I don't see where the REST URL for a map service is passed as a URL parameter in either of the examples.
derekswingley1
The same strategy applies. After you grab the URL using esri.urlToObject(), create a dynamic map service layer and add it to the map.
DonBarker
Thanks for this explanation.
So, it requires some Javascript coding.  Whereas, the example I provided for the ArcGIS.com viewer (above),
and this example of the AGXO (Silverlight) viewer
http://explorer.arcgis.com/?url=http://129.2.24.163/ArcGIS/rest/services/00_SMC_Environmental_Health...
require no scripting.  Or, please let me know if I'm missing something.
Don
derekswingley1
If you want to host it locally and/or do something not explicitly demonstrated in a sample, then yes, it requires a little code.
You're free to use the ArcGIS.com viewer or Explorer Online, though.
DonBarker
Yes, these are very cool.
And a core part of our San Mateo County strategy to publish our county geodatabase map layers using AGO resources; i.e. at little or no cost besides our existing investment in ArcGIS Server and geodatabase.
derekswingley1
Nice. If you're interested in hosting your data on ArcGIS.com you should talk to your account rep.
