can u check the code and tell me what is actually wrong in this ......when run it is not shown in the browser
3027
04-27-2015 09:58 PM
aneeshasatya
<!DOCTYPEhtml>
  <html>
  <head>
    <metahttp-equiv="Content-Type"content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <metaname="viewport"content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>Nalgonda point data popup</title>
        <linkrel="stylesheet"href="http://js.arcgis.com/3.13/dijit/themes/claro/claro.css">
        <linkrel="stylesheet"href="http://js.arcgis.com/3.13/esri/css/esri.css">
<style>
            html, body,
            #map
            .map.container {
            padding: 0;
            margin: 0;
            height:50%;
      #info {
         top: 2px;
         color: #444;
         height: auto;
         font-family: arial;
         font-weight: bold;
         left: 69px;
         margin: 5px;
         padding: 10px;
         position: absolute;
         width: 260px;
         z-index: 40;
         border: solid 1px #003300;
         border-radius: 4px;
         background-color: Green;
        /* Change color of icons to match bar chart and selection symbol */
            .esriPopup.darkdiv.titleButton,
            .esriPopup.darkdiv.titlePane.title,
            .esriPopup.darkdiv.actionsPane.action {
            color: #A4CE67;
        /* Additional customizations */
            .esriPopup.dark.esriPopupWrapper {
            border: none;
            .esriPopup.contentPane {
            text-align: center;
            .esriViewPopup.gallery {
            margin:0auto;
</style>
        <script src="http://js.arcgis.com/3.13/"></script>
<script>
    var map;
    require([
        "esri/map",
        "esri/dijit/Popup", "esri/dijit/PopupTemplate",
        "esri/layers/FeatureLayer",
        "esri/symbols/SimpleFillSymbol", "esri/Color",
        "dojo/dom-class", "dojo/dom-construct", "dojo/on",
        "dojox/charting/Chart", "dojox/charting/themes/Dollar", "dojo/parser",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane",
        "dojo/domReady!"
             ], function (
        Map,
        Popup, PopupTemplate,
        FeatureLayer, SimpleFillSymbol, Color, BasemapGallery, arcgisUtils,
        domClass, domConstruct, on,
       Chart, Dollar, parser) {
          parser.parse();
          map = new Map("map", {
              basemap: "topo",
              center: [78.8718, 21.7679],
              zoom: 4
          //add the basemap gallery, in this case we'll display maps from ArcGIS.com including bing maps
          var basemapGallery = new BasemapGallery({
              showArcGISBasemaps: true,
              map: map
          }, "basemapGallery");
          basemapGallery.startup();
          basemapGallery.on("error", function (msg) {
              console.log("basemap gallery error:  ", msg);
          //The popup is the default info window so you only need to create the popup and
          //assign it to the map if you want to change default properties. Here we are
          //noting that the specified title content should display in the header bar
          //and providing our own selection symbol for polygons.
          var fill = new SimpleFillSymbol("solid", null, new Color("#A4CE67"));
          var popup = new Popup({
              fillSymbol: fill,
              titleInBody: false
          }, domConstruct.create("div"));
          //Add the dark theme which is customized further in the <style> tag at the top of this page
          domClass.add(popup.domNode, "dark");
          map.infoWindow = popup;
          //          map = new Map("map", {
          //              basemap: "gray",
          //              center: [78.8718, 21.7679],
          //              zoom: 4,
          //              infoWindow: popup
          var template = new PopupTemplate({
              title: "munugode subdivision",
              description: "{village}:  {population} are affected",
              fieldInfos: [{ //define field infos so we can specify an alias
                  fieldName: "Number_Ent",
                  label: "Entrants"
                  fieldName: "Number_Sta",
                  label: "Starters"
                  fieldName: "Number_Fin",
                  label: "Finishers"
              mediaInfos: [{ //define the bar chart
                  caption: "",
                  type: "barchart",
                  value: {
                      theme: "Dollar",
                      fields: ["Number_Ent", "Number_Sta", "Number_Fin"]
          var featureLayer = new FeatureLayer("http://3092-ggngis:6080/arcgis/rest/services/BSESWithoutOwnership/FeatureServer/0", {
              mode: FeatureLayer.MODE_ONDEMAND,
              outFields: ["*"],
              infoTemplate: template
          map.addLayer(featureLayer);
</script>
</head>
<body  class="claro">
            <div data-dojo-type="dijit/layout/BorderContainer"
            data-dojo-props="design:'headline', gutters:false"
            style="width:75%;height:75%;margin:0;">
    <div id="map"
            data-dojo-type="dijit/layout/ContentPane"
            data-dojo-props="region:'center'"
            style="padding:0;">
    <div style="position:absolute; right:20px; top:10px; z-Index:999;">
    <div data-dojo-type="dijit/TitlePane"
            data-dojo-props="title:'Switch Basemap', closable:false, open:false">
            <div data-dojo-type="dijit/layout/ContentPane"style="width:100; height:100px; overflow:auto;">
            <divid="basemapGallery"></div>
</div>
</div>
</div>
</div>
</div>
</body>
</html>
RobertScheitlin__GISP
Aneesha,
  There were a couple of problems in your code.
  1. Properties of your html elements need to have a space between them
  2. Your Requires need to match your vars list (you were missing the require for ("esri/dijit/BasemapGallery", "esri/arcgis/utils",)
<!DOCTYPEhtml>
<html>
<head>
      on iOS devices-->
  <link rel="stylesheet" href="http://js.arcgis.com/3.13/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css">
  <style>
    html,
    body,
    #map .map.container {
      padding: 0;
      margin: 0;
      height: 100%;
    #info {
      top: 2px;
      color: #444;
      height: auto;
      font-family: arial;
      font-weight: bold;
      left: 69px;
      margin: 5px;
      padding: 10px;
      position: absolute;
      width: 260px;
      z-index: 40;
      border-radius: 4px;
      color: #A4CE67;
      border: none;
      text-align: center;
      margin: 0auto;
  </style>
  <script>
    var map;
    require([
        "esri/map",
        "esri/symbols/SimpleFillSymbol", "esri/Color", "esri/dijit/BasemapGallery", "esri/arcgis/utils",
        "dojo/domReady!"
             ], function (
      Map,
      //parser.parse();
        basemap: "topo",
        zoom: 4
        map: map
        fillSymbol: fill,
        titleInBody: false
          label: "Entrants"
          label: "Starters"
          label: "Finishers"
          caption: "",
          type: "barchart",
          value: {
            theme: "Dollar",
        outFields: ["*"],
  </script>
</head>
  <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width:75%;height:75%;margin:0;">
    <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" style="padding:0;">
        <div data-dojo-type="dijit/TitlePane" data-dojo-props="title:'Switch Basemap', closable:false, open:false">
          <div data-dojo-type="dijit/layout/ContentPane" style="width:100; height:100px; overflow:auto;">
            <div id="basemapGallery"></div>
          </div>
        </div>
      </div>
    </div>
  </div>
</body>
</html>
