Can I send another reverse geocode request with forStorage=true if I want to save the previous reverse geocode?
4463
01-15-2015 12:49 PM
MattMorrow
I'm using the reverse geocoder to fetch results against my database. I'm not storing the geocode result in my database so I leave the default forStorage value as false. However, If my database doesn't have the location that the reverse geocode returns, can I do another request to the geocode service with the for storage parameter set to true and then save that result?
I'm also under the assumption that using the reverse geocode service to fetch records against my database is not against the terms of service. I'm I correct here?
I'm using the free developer plan now and will start paying for a subscription when the app goes live.
Matt
BradNiemand
Matt,
As long as you aren't storing the results you get back from the service then you are in compliance.
Brad
BradNiemand
Matt,
"However, If my database doesn't have the location that the reverse geocode returns, can I do another request to the geocode service with the for storage parameter set to true and then save that result?"
Yes, if you want to store a value in a database, you would need to resubmit the request with the forStorage parameter set to true.
"I'm also under the assumption that using the reverse geocode service to fetch records against my database is not against the terms of service. I'm I correct here?"
Can you clarify this?  I am not sure I understand the question.
Brad
MattMorrow
Hi Brad,
To clarify, I'm using the reverse geocoding service with forStorage=false
on all requests and using the result it gives back to fetch records from my
database by City, State. If my database returns zero results because I
don't have the City, State then I would make an additional request to the
geocodig service with forStorage=true and save it to my database.
BradNiemand
Matt,
Brad
