Can I create an image from JavaScript API to add to a PowerPoint or Word Doc?
11356
29
12-07-2015 07:53 AM
JimSirianni
What I need to accomplish is to generate a map (client side) and highlight the county or zip code based upon geo locations that I have.
I also need to take that same map and generate an image that I can add to either a word or power point document.
Can this be done with ArcGIS?
I have tried with Bing and Google Maps and I am unable to create static images due to the url length.
ChrisSmith7
Honored Contributor
Jim,
In addition to Robert's suggestion, you can scrape the HTML from the map and launch a print window from the browser. In Chrome, I can send the printout to MS OneNote. In our mapping app, we allow the user to "export" an image/PDF using the ArcGIS print service, or, we allow the user to "print" using the HTML scrape.
JimSirianni
How did you accomplish this with a screen scrape?  There isn't a said image (tag) to scrape off the page.
ChrisSmith7
Honored Contributor
I simply create a blank HTML page from text in js. Inside of the page, insert the map content, which, in my case, is just the innerHTML of the document - document.documentElement.innerHTML (I pipe-in maps over an iframe, so I just grab the whole page).
You can then just open a print dialog and write the HTML, and voila, a scrape of the map.
JimSirianni
So you are just scrapping the div container and everything that is in it?  Also is this approach valid?  I was trying to go down this route for Google Maps but was told it could be in violation of the terms of service.
ChrisSmith7
Honored Contributor
If you're licensed for the product, there shouldn't be any issue with doing this - you're just printing the page. You may want to have a look at this:
Is the ArcGIS Server JavaScript API free to use? - Geographic Information Systems Stack Exchange
JimSirianni
So you were able to just grab the parent map div and scrape to an image?
ChrisSmith7
Honored Contributor
It's not an image - it would be a printout from the browser using a scape of the map's HTML - the browser might support saving as an image though. For instance, in Chrome, I can send the printout as an image to MS OneNote.
SteveCole
Honored Contributor
..or just Print Screen?....
ChrisSmith7
Honored Contributor
That would get my vote, unless they need functionality for users on the system.
JimSirianni
Not an option.  They have to be able to click a button and have that map image added to a document.
