Can a search widget be a non-editable dropdown list?
4008
07-16-2015 08:03 PM
ChrisSergent
I would like to do a search using an address locator and limit addresses to what is in the address locator. Is this possible? I need to create multiple searches on a form; is all of this possible. And if so, how?
RickeyFight
RickeyFight
Chris,
Have you seen this?
GeoForm
You can create a drop down off of it. I would assume that it uses domains.
ChrisSergent
That is a possibility. Any idea where the code is?
RickeyFight
Here: Esri/geoform-template-js · GitHub
I have used it one time.
ChrisSergent
Thanks. Now they want me to try something else, but this will work if the other option I am tasked to do does not.
