calcite.css Error: Module parse failed ArcGIS Core v5.0
947
03-05-2026 04:02 PM
ColbyMorris
I am getting the following error:
./node_modules/@arcgis/core/node_modules/@esri/calcite-components/dist/cdn/main.css:1:0 - Error: Module parse failed: Unexpected character '@' (1:0)
You may need an appropriate loader to handle this file type, currently no loaders are configured to process this file.
This issue has been presented in other threads. However, I still seem to get the issue in v5.0. I am confused as to what the issue is. I have followed multiple solution threads and nothing works.
I have read through the PRs in this github PR and it doesnt solve my solution
Version 3.3.0 distributes a file with invalid CSS that breaks Angular testing (`ng test`). Also affe...
I followed the Potential Solutions in the above link.
I first updated to angular 21. Surely if angular 20 could fix the parsing error. Then Angular 21 should be no different. This still didn't build the calcite-component.
next I built a custom WebPack where we compiled the .main.css using postCSS. This "Solved" the one issue with calcite-component.main.css But then the light.theme.css had issues building.
Is anyone else still having these issues building their angular apps?
ColbyMorris
Well, of course right after I posted this, I found my issue.
The PostCSS: postcss-loader did work as intended
However, I left the following in angular.json
            "styles": [
                 "node_modules/bootstrap/dist/css/bootstrap.css",
                 "node_modules/@arcgis/core/assets/esri/themes/light/main.css",
Which broke the build.
So, by removing these the build worked.
ColbyMorris
            "styles": [
