Calcite Accordion Loses Setting
590
10-14-2022 11:20 AM
MichaelWen_Timmons
I developed an ESRI JavaScript API custom widget with Calcite components. I set the Calcite Accordion's selection mode to 'single' and it worked as intended, but when I navigate to another widget and then back to the custom widget the Accordion now behaves as if selection mode is set to 'multi'. I copied the selection mode to the Dev Console and verified that the selection mode is still 'single', but it is allowing multiple tabs to be opened. Has anyone seen anything like this?
