bypass signin with hardcoded credentials
1902
03-28-2014 12:00 PM
JeffPace
Using token managed security, trying to bypass login with hardcoded credentials for intranet users. For some reason, even though the token comes back clean and the credential object is created, the login box still pops up? Shouldn't the IdentityManager know a token has been created and use it? I thought that is what the esri.id.initialize did
                            function initPredefinedSecurity() {
//alert('in initPredefinedSecurity');
                                serverInfo = new ServerInfo();
                                serverInfo.server = 'https://www.mymanatee.org/arcgis03';
                                serverInfo.tokenServiceUrl = 'https://www.mymanatee.org/arcgis03/tokens/generateToken';
                                serverInfo.shortLivedTokenValidity = 720;
                                esri.id.registerServers([serverInfo]);
                                var def = esri.id.generateToken(serverInfo, {"username": "util", "password": "util"});
                                def.addCallback(lang.hitch(this, function (tokenInfo) {
    //var idBase = new IdentityManagerBase();
           //get token creation time in epoch
                                var creationTime = (new Date).getTime();
                                                //calculate the token expiration based on short lived token validity
                                var expirationTime = creationTime + (serverInfo.shortLivedTokenValidity * 60000);
                                                //create array of secured services
                                var idObject ={};
                                idObject.serverInfos= [serverInfo];
                                var credentials={};
                                credentials.userId = "util";
                                credentials.server = "https://www.mymanatee.org/arcgis03";
                                credentials.token = tokenInfo.token;
                                credentials.expires = expirationTime;
                                credentials.ssl = true;
                                credentials.creationTime = creationTime;
                                idObject.credentials = [credentials];
                                console.dir(idObject);
                               //credential object is correct
                                    esri.id.initialize(idObject);
                                //sign in dialog pops up
ReneRubalcava
Esri Frequent Contributor
Could it be the map is loading before this line has a chance to run.
def.addCallback(lang.hitch(this, function (tokenInfo) {...}))
I can't tell when the initPredefinedSecurity() executes, but if you want to be sure it runs before the map loads, maybe try returning a promise so you can do
initPredefinedSecurity().then(function() { /*map load goodies*/ });
Again, I could be totally misunderstanding the sequence of events you have going here.
JeffPace
you are mostly right.  THey were loading simultaneously
I changed it to
esri.id.initialize(idObject).then(lang.hitch(function() {
initMap();
and it looks like esri.id.initialize is never coming back?
JeffPace
got it, but i don't know why
had to change
credentials.ssl = false;
but i am using all ssl, so no idea why
