Building a splash screen to tell the user the application is loading?
2753
6
12-12-2013 04:41 AM
IanPeebles
I am interested in building a splash screen that tells the user that the application is loading.  When the application is finished loading, I am wanting the screen to disappear.  Has anyone put something like this together?
I am looking at something similar to what the Silverlight Viewer displays.
Any assistance will greatly be appreciated.
BradleyNeish1
Thanks.  Will this only appear when the application is first loaded?  I don't want it to show up each time a user makes a zoom or pan on the map.
Yes this only appears when the application first loads.
From the reference: the map.on load event "Fires when the first or base layer has been successfully added to the map".
Depending on your specific application and the size/# of your layers you might be better served with the map.on layers-add-result event("Fires after all layers are added to the map using the map.addLayers method").
BradleyNeish1
to accomplish this I have a [HTML]<div id="wait" class="esriSimpleSlider">
<img src="ajax-loader.gif">
</div>[/HTML] that shows in the center of the screen.
Then using the map.on load event (which fires when the application has finished loading) i hide it.
loading = dom.byId("wait");
map.on("load", function() {
esri.hide(loading);
//other stuff
There are probably more elegant ways of doing this, but I hope this helps.
KenBuja
MVP Esteemed Contributor
Here's a sample that shows how to do that with a gif and here's one with text.
IanPeebles
esri.hide(loading);
//other stuff
IanPeebles
That isn't quite what I am looking for.  This animated .gif shows up when the application loads and when the user performs a zoom or pan on the map.  All I need is to have a screen come up one time each time the application is opened in the browser.
BradleyNeish1
IanPeebles
Thanks for all of the replies.
